steering wheel switches swap
700HP Facelift converted PFL C63 S Coupe
Don't forget to disconnect the battery or you'll get the airbag light.
part numbers a2229050604 and a2229050504 cost £230 pair. they do not fit out of the box as the edges are less rounded and they jam when pressed i solved this by adding small washers to the rear of the switch under the screws works fine
