Parking brake roll
Parking brake roll
weirdest thing happened this morning, went out like any other day to start the car, i started it up, i then proceed to release the parking brake... now sometimes the car might move a little bit, but while the car was still in park it continued to roll backwards and i had to push the brakes to stop the car from moving, kinda crazy but has anyone ever experienced this before ? Something with the electronics maybe ?
That would be an issue with the transmission. Your parking pawl wasn't engaged. The parking pawl locks the transmission in P. It's a mechanical lock that prevents the transmission from turning. It's not unusually for the parking pawl to get damaged, or maybe there's an issue in your valve body that prevented the parking pawl from engaging.
- so, OP grabs down there and releases the parking brake mechanically instead of using the electronic brake control? Why?
- OP wonders why the car rolls a little when the brake is released but the car is not in gear yet ("park" now just means you are not in gear yet as you already released the brake)?
I am either not seeing the tree in the Forrest or he makes a problem where there is none? What am I missing?
Uhm,
Uhm,
Or at least in the FL it automatically releases as soon as the transmission is put in gear.
So as I understood it, he manually released the e-brake, but transmission was still in P and the car kept rolling. Not just a bit, but kept rolling until he stepped on the brakes. So to me that sounds like the parking pawl didn't engage as it should. Nothing wrong with releasing the e-brake manually, even though it's not necessary, but the parking pawl should keep the car from rolling past the slack in the transmission.
and i did not know this, i just always used the release. I will try just driving and see when it releases
thanks
Now, you may indeed have an issue if the car really rolls (on an almost even surface) while you mechanically release the brake and still in P. Never tried that but the car will move some...just should not roll.
AMG C63s Sedan , AMG C43 , AMG G63 , GLK 250
or we talking that it was rolling feet at a time, and you were rolling , rolling , and needed to stop the car..
Yeah, my understanding is that this is how it's working in most newer cars with electronic gear selectors, partially in response to some recent incidents where people got out of their cars, not realizing that it wasn't in P and in Anton Yelchin's case got crushed to death by their own car because of it. So this is largely for safety. But it's convenient as well. I really like that I don't even have to put the car in P. Just shutting off the engine automatically puts it in P and engages the parking brake.
Stunna02 (09-14-2020)
2017 Mercedes-Benz AMG C63 Cabriolet, 2014 Ducati Multistrada 1200 S
Uhm,
Maybe it does with the newer models, my wife’s 2019 CLS does release the parking brake automatically when you put the car in drive and it sets it when your put it park.
My 2017 C63 does not release the parking brake automatically when you put the car in D. It only sets it automatically when you put it in park.
I prefer the old manual system of having a cable connected hand operated parking brake lever between the seats. So much simpler - you don't run into problems like this and changing rear brake pads are simpler. You do have to remember to set it on a hill and to release it before driving off (too inconvenient, too challenging?)
Hell, I remember parking on a hill intensionally so I could start the car if the battery died just by rolling and popping the clutch. I know... I’m old.
Nobody really used them, even when parking on a hill. I drove nothing but manual transmission cars for the first 20 years of my driving experience so setting the parking brake was something I did out of habit, it is kind of weird to me not to have to do it with these cars.
my 240z and 280zx (Turbo) but starters took a crap, so why spend the money on a starter when you just need a little "Roll" room and pop the clutch... lol
Most expensive thing I remember having to replace on those cars was the "Throw out bearing" and a "clutch" every now and then.
