C63/C63S AMG
Rough Idle and codes?
Old Sep 16, 2020 | 03:04 PM
.63AMG's Avatar
Hi, I bought a 2017 C63 a few month ago and It's been running great until today. Suddenly at the stop light it started to idle really rough and check engine light came on. I had a friend with a generic scanner plug it in and a bunch of codes appeared. P2A0B, P2279, P152C, P2180, P0300, P0308, P0305, P0306. We cleared the codes and they came back again after 30 minutes drive. The car is stock and out of warranty, I'm just wondering if anyone had similar experience and what might be causing it.
Old Sep 16, 2020 | 03:27 PM
SJGetsome's Avatar
W205 C63 AMG Coupe
How many miles are on the car? How many miles on the spark plugs? It might be due for a new set.
Old Sep 16, 2020 | 03:33 PM
.63AMG's Avatar
55k miles. I should've also added that this happened ~10 miles after I filled the tank with 93 octane from Costco, could it be bad gas?
Old Sep 16, 2020 | 03:46 PM
SJGetsome's Avatar
W205 C63 AMG Coupe
It could be bad gas. Since that's easiest to rule out, fill up at a different station when you need gas again and see if the problem persists.
Old Sep 16, 2020 | 05:51 PM
C63_01's Avatar
2020 Range Rover Sport P525 Dynamic
Had this happen to me when I had my Audi. Took it to dealership and they tested the fueled. Told me the gas in the tank was less than 87 octane even tho I had filled up with 93. I figured there was prob some sort of contamination in the fuel at the gas station. However, I typically fill up at Exxon, Shell, BP or Marathon. Havent had any issues so far on the Merc.
Old Sep 16, 2020 | 07:06 PM
mstraka's Avatar
amg C63s
I run Costco 93 octane - for several years no problem. It's a top tier brand. Also because of the volume sold I know I am getting fresh gas.
Old Sep 16, 2020 | 08:12 PM
.63AMG's Avatar
It's could be bad gas. When I pushed the button for 93, the blue light above it wasn't on as usual. I questioned one of the attendants and he told me the light is out confirmed from the price that I was getting 93. Maybe it was a malfunctioning pump and I got 87 instead?
Old Sep 17, 2020 | 11:35 AM
Jimmy_c63s's Avatar
Bad gas from the sounds of it. Have you cleared the codes yet? Did they come back at all?
Old Sep 17, 2020 | 02:01 PM
LessIsMore's Avatar
2017 AMG C63
I also have a 2017 and had the same problem, looks like most of the same error codes. I trouble shot and took it to an independent sop With no luck, ended up taking 2 dealer and they fixed it with an updated Flash. The service advisor said that this happened frequently due to cars needing the software update.
You can search my old posts on this forum for more info.
Old Sep 18, 2020 | 04:12 PM
.63AMG's Avatar
Thanks, I found your thread.
So I had about 1/2 tank left and filled with 93, added a full bottle of octane booster and drove a about 15 miles to run through any "bad gas" in the line. The car drives normal on the highway, but it's still a little rough at idle. If I keep it in sport+ which keeps rpm higher, It idles normal and I don't get any codes. If I switch to comfort, it idles a little rough and I get some codes. I got P2279 and P152C after driving in comfort for a few miles, including a few stop lights idling. I'm starting to think it might be vacuum leak somewhere. I will see if I can find anything, otherwise I will take it to the dealer.
Old Sep 29, 2020 | 09:09 AM
Jimmy_c63s's Avatar
Old Sep 29, 2020 | 09:26 AM
SJGetsome's Avatar
W205 C63 AMG Coupe
Originally Posted by Jimmy_c63s
Most accurate thing I have seen in a long time. Hahaha.
Old Oct 14, 2023 | 12:39 AM
Bleuc63s's Avatar
C63s
Im having same issues anyone find a solution?
Old Oct 14, 2023 | 10:26 AM
Shlick96's Avatar
2021 AMG C63S, 2008 C300
Check the Canister purge valves in the engine compartment on the left side. One of them might be sticking intermittently causing your problem. Disconnect them electrically and see if your rough idle goes away. You can also pull the hose off the side that goes to the gas tank and see if there is vacuum on the nipple. If there is you got a stuck open purge valve.
Old Nov 5, 2023 | 09:56 PM
alec w's Avatar
2018 Mercedes C63s AMG
Update?
Any update on these vehicles? My c63 just started the same problem and codes about 10 minutes after fueling up. Just drained the tank and got better fuel. Still misfiring on idle very bad
Old Nov 5, 2023 | 10:01 PM
alec w's Avatar
what was the problem?
