C63/C63S AMG
2020 C63s Stage 2 running 300 hp
Old Nov 3, 2020 | 07:18 PM
danielguo83's Avatar
2020 C63s Coupe
My 2020 c63s coupe, with a stage 2 tune, and a downpipe is only running a little over 300hp, have anyone have this problem before? and how to fix..
Old Nov 3, 2020 | 10:32 PM
Jimmy_c63s's Avatar
Sounds like you're in soft limp mode (low battery voltage error). Have you left the lights on, door open, or have a dashcam that's draining battery etc.?
You'll need this error cleared in Xentry. It should show a low voltage error.
Old Nov 3, 2020 | 10:36 PM
2020 C63s Coupe
i have forgot to close light once, but there is no warning light.
Old Nov 3, 2020 | 10:38 PM
Jimmy_c63s's Avatar
Yes, you're in Soft Limp Mode. There will be no dash errors or Check Engine Lights. It's very annoying and only a mechanic with Xentry can clear this.
You can read more about it here.
Old Nov 3, 2020 | 10:39 PM
2020 C63s Coupe
兄弟可以加个wx我看你wuhan的我wx是daniel20020320
Old Nov 3, 2020 | 10:44 PM
2020 C63s Coupe
but mine is auto lights tho., its 2020 model.
Old Nov 3, 2020 | 10:45 PM
Jimmy_c63s's Avatar
是的,现在是聚会时间!!!!! 886 🤗
Old Nov 4, 2020 | 07:52 AM
Dany1337's Avatar
W205 C63 AMG
Check your exhaust valves. They are a common problem. If they send en error the car reduces the hp extremly, because the car does not know if the valved are opened or closed.
Old Nov 4, 2020 | 07:59 AM
2020 C63s Coupe
i only have a downpipe everything else on exhaust is stock.
Old Nov 4, 2020 | 09:17 AM
FLC63s's Avatar
AMG C63s Sedan , AMG C43 , AMG G63 , GLK 250
how about just got get the car scanned , and then you will know if its something that got logged.. but if the car is running correctly and just limited, then its def in Soft Limp... :-)
Old Nov 4, 2020 | 04:32 PM
2020 C63s Coupe
yea, the car is running all gear and all rpm. Its just reduced hp and torque. Im thinking its 99% gonna be soft limp mode. But i dont know where i can take this to. Since i have no waranty and mb dealer gonna take 2,3 days just to scan my car.
Old Nov 4, 2020 | 04:34 PM
FLC63s's Avatar
i
what state / country you in ??
Old Nov 4, 2020 | 04:55 PM
2020 C63s Coupe
i
Im in California
Old Nov 5, 2020 | 08:05 AM
FLC63s's Avatar
Im in California
Your trying to tell me you are having a hard time finding a MB / European car repair / service location that has a Xentry tp scan your car ?? Most will do it at no or min charge , so they can earn your business.
Old Nov 6, 2020 | 02:33 PM
wassup61's Avatar
E63S4S
likely an exhaust valve issue
Old Nov 19, 2020 | 08:04 PM
2020 C63s Coupe
well just a quick update. it is the exhaust valve issue. Any one have a way to solve it without replacing the whole muffler?
Old Nov 20, 2020 | 11:34 AM
jopsis_c63s's Avatar
C63s Estate
AWE or ASR module for full open valves
Old Nov 20, 2020 | 02:51 PM
BMS's Avatar
BMS
Former Vendor of MBWorld
2018 C63 Sedan
You need to datalog it to see what boost, timing, and air/fuel are at with your tuning. Something like the JB4 has built in logging which makes that process easy and is compatible with both the factory flash or any aftermarket flash map you want to run.
Old Jun 4, 2024 | 03:52 PM
AManHasNoName's Avatar
2021 C63s
Yes you can
Yes you can replace just the valves without replacing the whole muffler as they just position on top held down by three 8mm bolts . I experienced this same issue of not more than 365 HP with the pedal to the metal on my 2021 C63s. The culprit for my case was the socket for the right side muffler. It needs to clip in securely, a quick pin exchange into a tight fitting socket solved mine. You can watch this video for more insight on how to get it changed >>>
