C63/C63S AMG
C63 best Camber Adjustment
Old Nov 17, 2020 | 06:37 AM
Dany1337's Avatar
W205 C63 AMG
Hey guys,
what is the best way to correct the camber on the front axle if you lower the car. I would take the "KW camber correction kit". Is there any cheaper option, that also works?
Best Regards
Dany
Old Nov 17, 2020 | 07:18 PM
tobeit's Avatar
AMG C63s
...KMAC kit?
Other than that...I just replace tires a bit more often as needed, love my camber. KMAC has good and bad reviews but apparently most bad are supposedly due to wrong installation.
Old Nov 17, 2020 | 07:53 PM
KAHBOOM's Avatar
GL450, AMG C63S Coupe
It’s not cheap but check out Carbahn Autoworks for their front camber kit. They use a factory arm with camber adjustable ball joints.
Very high quality, and no noise issues
Old Nov 18, 2020 | 01:33 AM
K-Mac's Avatar
SPONSOR
Mercedes-Benz CLK 550
FOR THE C63/S WE NOW MANUFACTURE A "TOTAL SYSTEM" WITH 3 OPTIONS FOR THE FRONT RE ADJUSTMENT OF "BOTH" CAMBER AND ALSO CASTER. WHILE FOR THE REAR 2 OPTIONS - AGAIN "BOTH" CAMBER AND ALSO "EXTRA" TOE TO COMPENSATE FOR THE NEW REAR CAMBER SETTINGS.
​​​​​​PLUS ALSO FOR THE REAR POPULAR UPRATED BUSHINGS FOR THE '6' MULTI LINK ARMS. LESS TWITCH, FLEX, LOSS OF TRACTION, ESPECIALLY WHEN APPLYING POWER TO LANE CHANGE / OVERTAKE.
1. FRONT SUSPENSION:
#503316-2 J
$380 (Both Sides)
Budget priced replacement upper arm inner bushings. Fast fit without arm removal (bush extraction tool included) 1.5 degrees Positive or Negative precise Camber adjustment. More than enough to resolve most costly, premature tire wear issues. At $380 (both sides) less than the cost of a high performance tire.
Also the security, peace of mind of "retaining the original HIGH STRENGTH FORGED ALLOY ARMS" - not replacing with welded, fabricated arms!
2. #503316-3 P $795 (Both Sides)
Complete " replacement" upper arms like above (#1) KMAC are not only Camber but also Caster” adjustable
These KMAC complete arms are same design as OEM. The security, peace of mind of high strength, forged alloy / not welded, fabricated.
Many brands provide Camber only. But “Caster” adjustment allows to compensate for Camber change plus correctly resolves steering pull.
3. #503316 K $480 (Both Sides)
Also front lower (not upper) replacement Camber and Caster bushings. Replacing at same time the 4 highest wearing, Providing again up to 1.5 degrees Positive or Negative Camber adjustment.
THIS UNIQUE KMAC PATENTED DESIGN allows precise single wrench adjustment – accurately under load, direct on alignment rack.
The 2 forward facing thrust arm bushes (now precisely Caster adjustable) unlike other brands set new standards - KMAC being Mono ball / 2 Axis, allowing arms to travel through their “required suspension arcs” without binding / locking up. Plus the advantage of improved “brake and steering” response by eliminating the soft rubber, oil and air voided OEM bushings.
ANOTHER KMAC DESIGN BREAKTHROUGH - bushings have more than "twice the load bearing, impact area" of often used steel spherical ball joints - that with their wafer thin teflon liners soon pound out.
FOR THE REAR SUSPENSION:
4. #502226 K $480 (Both Sides)
Lower arm inner bushings Camber (and also extra Toe adjustment to compensate for the new rear Camber facility). Precise single wrench adjustable.
* Note Adjusting “lower arms” retains top of tire to outer fender clearance when wanting to reduce costly, premature, inner edge wear.
5. #502226-1 M $595 (Both Sides)
Alternatively upper Camber arms (also extra Toe adjustment to compensate)
*Reduces clearance top of tire to outer fender when adjusting to reduce inner edge wear.
6. #502526 K $480 (Both Sides)
"Uprated bushings" for the '6' multi link rear arms. - less twitch, flex, loss of traction – especially when applying power to lane change / overtake
DHL Air worldwide $40 one kit, $20 each additional. PayPal, Visa or M/Card.
World's Largest Range Audi to Volvo. Competition Proven, Long term maintenance free, Non squeak, Fail safe lock system. All the features you would expect - Longest established. Most experienced, Adjustable Strut Tops and Bushing Kit Manufacturers.
Old Nov 19, 2020 | 07:38 AM
Dany1337's Avatar
W205 C63 AMG
I think i will go with the "KW Camber Correction Kit". It is the best pricing option and does what it needs.
Old Aug 30, 2021 | 10:11 AM
jonathandean's Avatar
2018 c63 coupe
MB front camber settings
I have a 2018 C63 Coupe with 18 inch wheels, Michelin pilot super sports 255/40 ZR18. I am trying to find out the official MB front wheel camber settings. The tyre fitter says they are between minus 1.51 and minus 1.08 whereas my actual settings are between minus 2.15 and 2.18.
Does anyone know the official MB settings for my car?
Many thank, Jonathan
Old Aug 30, 2021 | 01:03 PM
1slick_c63amg's Avatar
C63 AMG
General question - when lowering, is it mostly the front that gets out of wack? I just got an alignment done on stock suspension, camber F&R is between -2.0 to -2.4 which is good for me... I like a little negative camber. C63s come like that out of the factory. Factory range for the front are -1.5 to -2.2 range for camber. Toe was within spec as well. Curious how much worst it gets within a mild lowering? @tobeit Do you know what you're running right now?
sub'd.
Old Aug 30, 2021 | 01:08 PM
tobeit's Avatar
AMG C63s
sub'd.
Yes, front is -2.8/-3.1, rear is a little less around -2.4/-2.6. Front wear much faster than rear.
Old Aug 30, 2021 | 01:22 PM
dctwc63s's Avatar
2019 C63S Sedan
sub'd.
Our cars come with pretty aggressive camber from factory. My sedan had same range of camber as you before lowering and after lowering with eibachs (0.8in front 0.4in rear) they went up by .2 or 3 on the fronts. The rears I had camber arms installed and set the camber to oem specs. Camber might be a tiny bit more now since the springs have settled.
If anyone is curious about tire wear, after 11000km my front tires are still fine. Wear looks even to me and no signs of premature inner edge wear (checked when my car was on a hoist few days ago).
Old Aug 31, 2021 | 06:04 AM
2018 c63 coupe
C63 best camber adjustment
Thanks to all of you for your replies. I am now comfortable that my car is within OEM tolerances for front wheel camber and that unless I am prepared to have camber adjustment fitted I will have to accept that the tyres will wear predominantly on the inside edge (which they do and evenly). Current front tyre life is around 9000 miles or 14000 km but then I only purchased the car for its looks, wonderful sound and effortless power on longer journeys. I am far too old and timid to use anything but a fraction of its capabilities.
Old Aug 31, 2021 | 08:46 AM
mischief's Avatar
W205 AMG
You can most likely fix your inside tire wear by getting an alignment to adjust the toe. The factory specs for toe have it being toe out (-ive toe) which promotes inside tire wear. Getting your toe more neutral (as close to 0 as possible) should help your inside tire wear issue.
Old Aug 31, 2021 | 09:01 AM
dctwc63s's Avatar
2019 C63S Sedan
Yep I forgot to mention front toe. I had my front toe set to 0 which is probably why my tire wear is as it is.
Old Aug 31, 2021 | 01:28 PM
2018 c63 coupe
Once again, thank you all for your thoughts. My recent Vehicle Alignment Report states:
Camber:
Front Left - MINUS 2 degrees 15 minutes
Front Right - MINUS 2 degrees 18 minutes
Toe:
Front Left - PLUS 0 degrees 16 minutes
Front Right - PLUS 0 degrees 12 minutes
Toe puzzles me as you have all said that OEM settings are negative not positive.
Many thanks, Jonathan
Old Aug 31, 2021 | 04:18 PM
shootermcgav1n's Avatar
C63S
Interesting thread. I'll likely be getting an alignment myself in the coming days and will report back where I'm sitting also. I'm lowered on H&Rs.
Old Sep 1, 2021 | 03:53 PM
C63 AMG
Very helpful insight. Thank you both!
Old Sep 1, 2021 | 04:42 PM
tobeit's Avatar
AMG C63s
btw, if you need a K-MAC front camber kit I have one available. Decided not to install it and instead change tires more often
Old Sep 1, 2021 | 04:53 PM
cornerjunkie's Avatar
none
Has anyone tried these? KW Camber Adjustment
Given the annoyance KMAC's posting gives me along with the reports of the installation being a nightmare, I'd rather go another route...
Old Jan 28, 2022 | 08:50 PM
anwar_hamoude's Avatar
2016 C63 AMG
KMAC solution looks like the best option. If I am reading it correctly. I want symmetrical alignment. I prefer to be slightly aggressive with camber. Car is at stock height.
As I understand it, KMAC front bushing kit. Factory bushings for front control arms are replaced with adjustable bushings, both spring link and lateral arm. That will correct the caster and camber.
Camber, top of the tire can be adjusted with upper wishbone inner bushing kit.
If caster was symmetrical then the upper wishbone bushing replacement would correct just the camber?
I am curious to know how pushing the wishbone in or out affects caster. I am wondering if both sides are set symmetrical with the wishbone kit, -2.5 degrees would the caster then be symmetrical?
The rear alignment seems less complicated. I am not certain which is the correct kit. Will either do the job?
502226 K R, [size=16px]This kit has C63 mentioned but also 4MATIC.
502226-1M, Turnbuckle and toe, W205 is listed.[/size]
I replaced the left spring link due to squeaky ball joint. I don't know if that corrected or worsen the variation in the front alignment. I figured on replacing the right spring link next. Replacing all of the suspension parts is little expensive. Then having to pay $200 to have the alignment checked- Plus the fact they can only move the toe in and out makes it seem like a real waste of money.
Adjustability should have came stock. Adding adjustable bushings is a lot of money to dishout just to achieve proper alignment.
Old Jan 30, 2022 | 09:56 PM
K-Mac's Avatar
SPONSOR
Re C63/S - answer to your queries.
But damn - did not want to upset #17 any more then necessary so reply have set out as a attachment.
Re your mention "Adjustability should have come stock"
Yes, you would think some accountability would be directed to the highly profitable new car manufacturers creating cost savings by there deletion.
KMAC's role in the aftermarket industry being to provide a solution to the fact the often quoted "Full '4' wheel alignment" is only 'Toe' directional adjustment. With most owners unaware, but convinced surely there must be "Full ongoing adjustment" to resolve costly, premature edge wear !
Presuming instead continued premature replacement is either - lack of alignment expertise or result of incorrect choice of tire brand !
Spoiler
Old Jan 31, 2022 | 01:29 AM
2016 C63 AMG
The cost of replacement parts is frustrating. Ball joints are not replaceable, the entire control has yo be replaced. Plus the cost of additional speciality bushings. I want the alignment dialed in for performance- the only way is to allow for adjustment. I believe KMAC solution is the most viable option. I have added front and rear bushing kits to my parts list. Ball joints are higher on the list.
Old Feb 1, 2022 | 10:17 PM
kfehling's Avatar
2015 C63 AMG S Edition 1, 2021 GLS63, 2020 McLaren 600LT Spider
I can definitively say that the K-Mac kit is the best and is what I use. Take a look at my ThunderHill track day thread and you can see all the mods I have done to make my car perform better on track. Without a doubt, the K-Mac camber kit was one of the best bang for the buck mods I did. If I remember correctly, I was able to get about -2.5 or -2.75 on the front and that was night and day on the track. Yeah, it still understeers a bit but the compromise is that I can run this amount of camber on the street as well and it does not adversely affect my tire wear beyond what I would expect. If you plan to track your car, get this kit. If you just want a bit more performance on the street, get this kit but keep it around -1.5 or perhaps even -2; you will notice a profound difference in handling.
Kurt
Old Apr 13, 2022 | 06:07 PM
Iridium.C63s's Avatar
16' C63s, 22' RAM 1500
Im getting nasty wear on the inside of my front tires... just purchased Kmac Front camber & caster kit (Kit #503316-K). Sucks stock setup can't be adjusted more to help with this problem.
Great customer service btw if anyone decides to call them directly.
I'm on stock ride height btw.
inside rim damage is from my local carwash... never going back there again. the tire width is too wide for that carwash. Lesson learned!
Old Apr 13, 2022 | 06:10 PM
Kurt
Thanks for those numbers! I was looking at what other peeps had for those settings.
Old Apr 15, 2022 | 12:22 PM
rmarchigiani's Avatar
C63s Coupe
Here are my numbers, before (top) stock suspension and after being lowered on HR springs with 15 mm front and 12 mm rear spacers from supreme power (bottom).
Old Apr 19, 2022 | 07:49 PM
noremaC's Avatar
17 C63S Coupe PTG1000
KMAC’s options are somewhat confusing.
Just ordered Eibach Pro Kit lowering springs. While I have my shop install them, I’m going to have them install a Kmac kit.
Is the $295 2-piece front camber only kit sufficient? It seems it will adjust camber and toe to prolong tire life. I don’t need crazy levels of adjustment for the track. This is a weekend car.
The rear kit(s) for the C63s seem to be a bit more involved and expensive. Are they required? From what I read, when lowering the car, the fronts get more out of alignment spec than the rears. Thoughts?
@K-Mac - if I need to adjust camber and toe for when I lower the vehicle with springs, just for the purpose of saving tires (not for tracking the vehicle), at a minimum, which product(s) do I need? Thank you!
