C63/C63S AMG
Installed Michelin Cup 2’s
Old Dec 29, 2020 | 09:08 AM
elitex's Avatar
2020 C63S Coupe, 2021 Bmw X5M Competition
Just showing you guys the pictures of the rear tires. They are both exactly the same factory size. Cup 2’s run wider and actually look better.
Pilot super sports
Pilot Cup 2
Old Dec 29, 2020 | 09:43 AM
boosted20v's Avatar
2020 AMG GT63s
How much more grip?
Old Dec 29, 2020 | 09:53 AM
tobeit's Avatar
AMG C63s
Sure looks a lot different but part of it maybe optical illusion (?) as the PSS have that rim protector and the cup 2's don't (its much smaller).
Old Dec 29, 2020 | 11:22 AM
elitex's Avatar
Definitely not optical illusion. Looking at actual specs, cup2’s are wider in MB spec.
Old Dec 29, 2020 | 01:56 PM
superswiss's Avatar
2019 C63CS
According to Tire Rack, the Cup 2 has about .5" wider tread width, however, they look more stretched in your picture, not wider. The wider part is the extra rim protection that the Cup 2 and PS4S have. Here's a pic of my PS4S for comparison. They also stretch less than the Cup 2. You sure they are the same size?
Old Dec 29, 2020 | 03:09 PM
elitex's Avatar
Top picture is clearly more stretched than the bottom. To me, cup 2’s seems less stretchered than your PS4s? Are you on stock size?
Old Dec 29, 2020 | 03:13 PM
elitex's Avatar
More angles on Cup 2’s.
Old Dec 29, 2020 | 03:20 PM
superswiss's Avatar
2019 C63CS
Oh never mind. I lopsided the picture labels. Didn't realize your top picture was the PSS. Yes, you are right, the PSS is far more stretched, so now it makes sense. Yep, the PS4S would be a bit more stretched. The PS4S has 9.9" tread width and the Cup 2 has 10.5". So the Cup 2 is the same width as the wheels and therefore will be square pretty much. Interesting thing is the PSS has a tread with of 10", but it looks far more stretched on the wheel than the PS4S. A little bit of stretch stiffens the sidewall around corners. Basically makes the tire less likely to roll over the sides and improve handling.
Old Dec 29, 2020 | 03:42 PM
elitex's Avatar
Agreed about the little bit of stretch. PSS’s are a little too stretched IMO.
Old Dec 29, 2020 | 07:22 PM
BrianShaw23's Avatar
2019 AMG G63, 2020 AMG C63s Coupe
I got mine in Cup 2s from the factory. Great tire, I'm on ps4s right now and the main difference to me is the car absolutely handled and turned better with the Cup 2s. A bit more grip/handling when doing tight turns on a windy canyon road with the Cup 2. Ps4s definitely quieter and more comfortable and surprisingly has close to the same peformance as the Cup 2s overall.
I went 255/305 ps4s but will probably go back to stock size, I feel like the car will handle and turn better with stock size, small difference but my preference over the little bit of more traction going wider. The car will spin no matter the width if the tires aren't hot.
Old Dec 29, 2020 | 07:35 PM
superswiss's Avatar
2019 C63CS
The PS4S took a lot of the learnings from the Cup 2 and applied it to a more exclusive street use with a tire that can handle wet and dry conditions. The Cup 2 needs sufficient heat in them to perform and they don't do so well in the wet. Another important difference is that the Cup 2 starts at 7.2/32" tread depth whereas the PS4S starts at 9.5/32". That extra tread depth gives the PS4S more flex at the beginning until you wear them down closer to where the Cup 2 starts. Dry grip/handling improves as the tire wears down, because those grooves are only there to expel water, but actually are counterproductive for dry handling.
Old Dec 29, 2020 | 08:07 PM
elitex's Avatar
I may buy forged HRE’s and get PS4’s for those wheels. So Cup 2’s for warmer months and PS4’s for colder. We don’t have much of a winter in Atlanta so PS4’s will be just fine.
I did replace PZero Corsas on my previous car to PS4’s and I felt that you definitely give up some of the aggressiveness of the proper trackable tires but you gain far more traction in cold/wet days.
Old Dec 29, 2020 | 08:32 PM
AMGBEASTMODE's Avatar
20 Lamborghini Urus, 2021 G63
Actually just picked up a 2021 C63 AMG S coupe today for my gf to drive that came with Cup 2's. SO, If anyone is interested, I'll probably list soon. She has NO need for them and I had the dealer swap them out for PS4's. I've had them on my GT cars for myself, but it takes skill to drive with those tires in other than optimal driving conditions!
Old Dec 29, 2020 | 11:12 PM
Gazwould's Avatar
S204 C250 CDI Sport
Excellent demonstration how different tyres are not produced to precise sizes , there is manipulation !
To some this is like telling them that the world is a flat disk .
Also happens to the aspect ratio too so throws out those online calculators .
Welcome to the real world .
Old Dec 30, 2020 | 04:40 PM
///Bruce's Avatar
2020 AMG GTC Coupe & 2018 Macan Turbo
Looks great Elitex
Old Dec 30, 2020 | 04:58 PM
elitex's Avatar
Yeah exactly. when I replaced Pirelli PZero Corsas on my previous car to PS4S, Michelin were narrower. I had to go up one size.
Another thing that makes this even more interesting is that the same model tire could be different depending on OEM designation.
Old Dec 30, 2020 | 04:59 PM
elitex's Avatar
Originally Posted by ///Bruce
Looks great Elitex
Thanks!
