AWD W205 C63s?
https://www.autoevolution.com/news/8...ing-69688.html
yea i heard about that conversion and ive also heard of someone on the coding forums say his shop has done an e63 awd 4matic+ drivetrain conversion into a c63. its going to be expensive either way. just buy a big pair of big rear slicks for the 63 and only rip in good weather or mod a 43 to be a 63 power level and handling like i did on my 43. I was really hoping for the new c63 to be awd v8 4.0. but now we gotta work with what we got. Turbos it is!
also
yea the c43 has no e-diffs which is unfortunate but they do some level of torque vectoring with the brakes which also acts sort of like a diff on starts as it controls the slip on lighter wheel. If it was possible to retrofit the 43 awd into the c63 which I dont think it is due to different trans nor would it be worth it, it still would be better than rwd from a dig.
open diff 4matic c43 still relevant
this was done on the street on winter tires in Michigan. 1.72 60ft not bad for a cold street.
With that said, no one has converted to AWD. I think the only candidate where it could potentially work is on a Facelift C63 Coupe. Not a sedan, and no pre-facelift. You need the 9 speed trans (or at least any tunnel modifications made to accommodate that new trans) as well as the Coupe’s rear end because it’s shared with the E63S (unlike the C63 sedan).
Nothing’s impossible, but I think a facelift Coupe and sourcing a E63S 9 speed awd trans and axles is the best starting point. If it was done in a prototype stage, it can be done aftermarket. Just depends on how deep your pockets are, because I wouldn’t expect a project like this to be less than 30k.
...would likely be cheaper and better results if you sell your C63 and buy an E63.
