C63/C63S AMG
Focal plug and play speakers
Old Aug 8, 2022 | 09:25 PM
WTC43AMG's Avatar
2018 G63, 2018 C43, 2018 GLS450
Originally Posted by cls5504matic
Interesting makes sense given the unusual speaker setup.
Did the installers mention any areas of particular that needed dynamat/sound insulation?
The doors definitely needed quite a bit especially in the back since I have the window shades for the kids. The back deck was also problematic. The little plastic flaps for the car seat anchors on the back deck were making noise as well. You can just take them off though.
Old Oct 3, 2022 | 03:49 AM
C60 Free's Avatar
C63 MY15
Focal Isub MBZ?
Has anyone given the ISUB by Focal a go?
specifically interested to hear what improvement it brings when just the subs are installed in an otherwise stock Burmester system
TIA
Old Jul 20, 2024 | 08:58 PM
noremaC's Avatar
17 C63S Coupe PTG1000
Reviving an old thread.
Ive been running the ISUBs for about a year now - significant upgrade from stock. Even on stock amp.
Just installed the ICC MBZ100 (center channel) and IS MBZ100 (2 ways) in the front doors. I have a coupe and the tweeter location is in the front door directly beside the woofer. A lot of the videos and instructions show the tweeter on top of the door card against the window in a separate enclosure. What’s interesting is there are separate signal wires to both the tweeter and woofer, however the supplied crossover with the IS MBZ100’s only have a single input connection. I’ve just connected it to the woofer OUT signal wire and seems to operate fine. Left the tweeter IN signal wire disconnected and taped it away.
Curious if anyone has figured out good EQ settings with this setup?
Likely needs a proper DSP and amp - Match UP10 DSP.
Old Jul 21, 2024 | 10:20 AM
Solo wing's Avatar
2020 E 300 Coupe and 2019 GLS 400
So I am in the same boat. Just received my Focal order. Center channel and the front 2-way speakers. These will complement the Focal MBZ iSUB already installed.
Looking at the Focal user manual, I wouldn't need to install the protection adapter nor the passive crossovers sine the factory Burmester system already has a S****y AMP+DSP.
Old Jul 21, 2024 | 04:33 PM
FDNewbie's Avatar
'17 AMG S63 Convertible, '17 AMG C63S Edition 1 Coupe
In addition to the sound quality, how is the volume? One of my issues regarding the OEM audio system (in addition to sound quality) is volume. On my vert, I can't really hear much at all with the wind noise, as the volume doesn't go up very high. Prob a limitation of the OEM amp. This is in stark contrast to say, the BMW M4 vert with Harman Kardon sound system; it was plenty loud & clear, even with the top down.
Old Jul 22, 2024 | 06:40 PM
noremaC's Avatar
@FDNewbie @Solo wing
That is one thing I’ve noticed - a direct speaker swap without messing with EQ - the Focal speakers are way too bright. Not sure if adjusting with the stock EQ and DSP will change that. Maybe it can help? Not sure what to mess with in the Burmester EQ or Spotify EQ.
I have the feeling installing a proper AMP/DSP is the only way to tune these speakers to sound good.
Old Aug 28, 2024 | 12:53 PM
  #32
Mike_D_GLE450's Avatar
2024 GLE 450 2016 s65 Coupé
Has anyone tried the focal swap on a 2024 GLE? Crutchfield now has all those Focal speakers but says, "Not sure if they will fit." The Focal sight does not list GLE for replacement. Wasn't sure if anyone has tried or do they actually not fit.
With a 60 day return policy on Crutchfield I would be half tempted to just give it a try if no one has.
Old Sep 14, 2024 | 12:43 PM
  #33
I ended up just swapping the subs on my 2024 gle and it does sound better. But did not go with focal, went with the match up. Made the mistake of doing the Crutchfield which were the 4.0 not 4.2 and had to return them.
Found the 4.2 on ebay and am more than satisfied.. for now.
