Factory PSS just keeps spinning at launch
- Put the suspension in Comfort for more squat and weight to the rear, and lower your rear tire pressure
- Lower the launch rpm. AMG Driving Academy instructor recommended 3200 instead of the default 3500
- Heat up the tires first and lay down some rubber. Tires grip much better on a layer of their own material on the tarmac than the tarmac itself. That's why drag racers do a burnout first.
- Do it on a warm day
- Play with the traction control and find the right balance between wheel spin and traction
What width are you running up front?
i'm debating 295 vs 305 and figured 265s would be more suitable than stock width.
I thought you cannot do a burnout with this car. And temp was around 19C. I had TC off all the way. The car was still bogging down. I am not into drag racing anymore, I was just trying to make the sure the car can put down the numbers it is supposed to put down.
im thinking about changing the standard super sports to wider PS4S, my car is lowered with spacers so trying to decide on what size to go with.
Any help would be appreciated
Hope it helps. Let me know if you want any other shots.
One of the tire shops said they have a used pair of 305/30/20s in the stock PSS with ~85-90 thread. This is a pretty good deal since the price is half but for those who swapped, is the difference between PSS and PS4 big enough for me to hold off and wait till the P4s are back in stock? Thanks.
ive had the car for 3 years now and for a change i want to get it tuned. the stock tires are uselss on stock power so wouldnt you really need to upsize in this case? i just cant see how the car will even be drivable in an aggressive manner with a tune and stock tire setup?
