C63/C63S AMG
How dangerous are our cars at high speeds?
Old Jan 16, 2022 | 04:28 PM
  #76
See63r's Avatar
2020 c63s coupe
This smoking tire review of the carbahn c63s coupe has a point on 15.15 where he mentioned a little wriggle under hard braking.. I think that is what I felt on my rear as well. It just feels like the rear of the coupe is not as planted as it should be.
Old Jan 16, 2022 | 04:34 PM
  #77
superswiss's Avatar
2019 C63CS
Originally Posted by Engadine
Would you recommend these tyre pressures on a C63S with 19/20s for everyday fast driving for MPS4S also, or just for autobahn speeds?
Yes, I would and I do. The higher pressures are only needed if you load up the car or drive above 155 mph for a prolonged period like on the German Autobahn. The higher pressure allows the tires to cope with the deflection and not overheat. I spent two months in Europe with mine, and even there I kept my pressure at 33/32 most of the time. No issue during high speed braking maneuvers when somebody pulled out in my lane not seeing me. The only oh **** moment I had was that one time a van pulled in front of me and the road was slightly damp and ABS kicked in at north of 150mph. That gets your heart pumping for a moment. Occasionally going above 155mph is no problem at those pressures, either. Just keep an eye on the tire temperatures and slow down if they get hot.
EDIT: Just to further underscore this, on the track you'd use even lower pressures. You'd actually want the hot pressure to be around this when going on the track. I made the mistake of not lowering the tire pressure when I went on the Nürburgring, and the car became very floaty as the pressure increased under the heat.
