C63AMG W205 Juddering and Jerky under Acceleration
I drove the car today on a hot day, around town, in a spirited manor and it didn’t miss a beat. However, I think the key here is I didn’t remove my foot from the accelerator for more than a few seconds to let it coast.
I have not experienced the high revs required from cold start to get it moving, other than if I washed it the day before and the callipers seized a little, or to release the hand brake. I have never applied the handbrake manually, I just let the car do it and drive off with it on. Sometimes, depending on slope this requires a little more throttle to remove the handbrake.
If coils don’t fix it, I’ll take your advice and look harder for a specialist in current AMG’s.
It is worrying just how many issues seem to be out there for this car, a potential money pit.
These can be a handful to own and the problems our cars present at such a young age is quite disappointing 😒
Hoping your issue gets fixed soon mate. Please keep the thread updated with your findings.
I will certainly let the forum know if I can get to the bottom of this issue.
I'm new on this forum and am using it as a last attempt to save my 2016 C63AMG W205 coupe. Any help or advice will be greatly appreciated. 20,000 miles and owned since new. Fully serviced by MB under service plans.
I have throughly researched the net on my problem and no existing issue is sounding exactly the same.
My car judders under acceleration once it's warm and has been running for 15 minutes.
It's been into Mercedes twice and they cannot find a fault code so to them it isn't a problem. They have applied an update to the ECU but it still has the problem. Feels like it is being strangled, it judders and hesitates under acceleration. If I am very violent with the accelerator and get it to kick down multiple gears, i can get it to clear. It is fine on 100% throttle but anything below seems to cause hesitation/juddering and an uncomfortable ride when warmed up. Also I only ever used Shell Optimax 99 octane.
I have started to tick cheap things off the list;
Into Mercedes twice for diagnosis - couldn't find anything wrong or get the problem to re-occur. Software update applied.
New spark plugs (seemed better for a day then back to normal)
Re-set gearbox (needed doing but didn't fix the issue)
Into Independent garage that also couldn't recreate the fault but found an exhaust flap sensor 2 had come up. Cleared and it hasn't come up again. But still didn't fix the issue.
It feels to me like a dirty MAF sensor (from experience with other cars)- but the C63AMG w205 doesn't seem to have these. Are there any other sensors that could be dirty that would cause this issue and not throw up a code? Also the fact no code kind of rules out coils and oxygen sensors.
Once the car is parked up if i take it out when it's still warm it will do it straight away. If i leave the car for over an hour, it is fine again for another 15 minutes until warm and the problem starts again.
Any help will be greatly appreciated as i'm mentally getting prepared to get rid of the car - but I really don't want to as it drove so nice for the first 20K and still looks great.
your not alone, my 2017 is doing exactly the same. Its in next week to have all the coil packs and spark plugs changed so I’m hoping that this will clear the juddering.
Mercedes gave it a B service with plugs and gearbox changes just before i brought it and the previous owner didn’t experience any issues, true or not! So it went back to them to check it over, they couldn’t find anything wrong with it so i took it to a local Merc specialists who when drove it said i can feel the issue but cant find it. Another specialist drove it and said its my Torque convertor but that day a code came up saying cylinder 5 was misfiring. So fingers crossed its the coils otherwise its going to Webuyanycar!!
one thing i did notice was that as soon as the juddering started if i came off the accelerator a little and reapplied it would go briefly but came straight back.
I’ll keep you posted, let us know how you get on.
Well hopefully its the coils, the garage did say that MB could have damaged the coil sleeves when they replaced the spark plugs. I’ve been told that Failing coils wont show up a fault code even though they show signs. Dreading but cant wait for them to be done, pricey but worth it if it rectifies the issue.
where abouts are you?
I'm north London and a local mechanic that worked on my previous Audi RS models is doing the coils. After my experience with Mercedes over the last 8 years with my AMG's I don't really trust them or their mechanics anymore.
Let me know if it works. Mine's booked for coils next Friday due to work commitments. I'll do the same and update the forum.
Do i just need to bite the bullet and replace all 4 or is it likely to be just one? Also any idea on costs as it they seem difficult to find on Google. Cheers!
sorry if the videos are Sh**** lol!
As for the issue I’m now stuck, either get the Torque converter changed as suggested by another mechanic or give it back. Decision time!!
let us know how you get on. Good luck
). No codes.seemed to be within the 3-5k rpm range. whole car shakes forward and back and all you see is the rpm stutter up and down before it shifts after it kicks down a gear to pickup. after that its perfectly fine.
Driving it hard does not reproduce the issue. and driving it calmly sometimes presents it but not as noticable. I initially thought it was the wheels not keeping traction lol
He said power delivery issue. Thank goodness I have a warranty!! Will keep you all posted in the case yours hasn't been resolved yet!
When in COMFORT mode, the car starts off in 2nd gear, thus needing more RPMs to move etc... putting the car in another mode, allows it to start off in 1st gear.
https://youtu.be/15MPtQAQ914
https://youtu.be/jtI7a2njyVw
https://youtu.be/62MzRe4WgB8
If the car is acting up part throttle it's reading off o2 sensors and wide open throttle it's going off closed loop values.
log your fuel trims and see if the car is running lean part throttle also.
Also inspect the o2 wire harness to see if its loose or damaged. Our cars are extremely hot in that area and can be wire harness related also.
As this did not work out, I brought it back to the dealership and told them, that I would not take the car back, unless it would run great again. O2-Sensors were replaced by my dealership before asking Mercedes-AMG Affalterbach for help, as those sensors showed signs of aging.
All that stuff did not help.
