Extreme power loss on c63s
You need a 50 dollar pair of awe valve simulators as long as your car is pre facelift (not sure if they make them for facelift models now). They plug into the wiring harness that uses to plug into the wiring for each valve on your muffler. Search the forum for the proper procedure to do it (is. Car asleep, etc)
Edit: Here...
https://mbworld.org/forums/c63-c63s-...ulators-3.html
Three weeks ago I did a backbox delete on my 17’ C63S. After the delete my HP Gauge stopped going all the way to 500+ hp and only showed ~460 hp max. Next day the car went into limp mode (no code thrown or CEL) just power limited to 350hp max! Started investigating on forums about this. And is a common issue and a headache to solve. Happens because the cars senses the exhaust valves arent working properly and sends the car into limp mode.
Went with a local tuner so that they could code out the exhaust flaps, to see if that could solve the problem! It did to a certain extent. The car was out of limp mode, however the power was still only reaching 460hp and i could feel the lack of punch. Kept digging into it and found out the car even with the flaps coded out, sends the car into a Soft Limp Mode which cant be detected by normal scanners! Only Xentry system of MB can detect it. Been dealing with this problem for 3 weeks now. I reverted my backbox to stock. And still just shows 460hp on my HP Gauge! I asked a local mechanic with xentry to check it out and says no code shows in xentry! I dont know what to do. Maybe take it to the MB dealer? I took it to a dyno and showed 503hp however my HP Gauge inside the car only goes up to 460HP.
