C63/C63S AMG
race exhaust mode
Old Jul 28, 2021 | 06:24 PM
greenwave77's Avatar
CLK350
race exhaust mode
Greetings to all, longtime reader, first time posting. I have a 2017 C63S Coupe. Race mode transmission works but have lost the race performance exhaust mode. My mechanic had it on the lift and I manually went throught the settings via the center console and all others worked. Any thoughts would be much appreciated. Thanks!
Old Jul 29, 2021 | 11:57 AM
FDNewbie's Avatar
'17 AMG S63 Convertible, '17 AMG C63S Edition 1 Coupe
Do you mean that you can enable the exhaust valves to open, but it doesn't get louder?
Old Jul 30, 2021 | 06:18 PM
CLK350
Yes. It appears that the flaps are moving some amount but my mechanic wasn't sure what "position" it should be in to significantly increase the sound.
Old Jul 30, 2021 | 10:42 PM
raphman's Avatar
'16 C63s
The center h-pipe flap should be perpendicular to the car when sport exhaust enabled. The flaps at the mufflers should be parallel to the car.
Old Jul 31, 2021 | 07:34 AM
CLK350
Thanks, that gives my mechanic something to work towards!
Old Aug 16, 2021 | 06:17 PM
CLK350
UPDATE: My mechanic had the car for 2 days and tried every conceivable flap postion and no improvement in sound in race mode. He called a tech at one of the local dealerships and the tech said that there is no sound difference between sport+ and race. I personally know that to be bull*^$# because the few times I used race mode when I first picked up the car it was exceptionally louder. Any help or suggestions going forward would be most appreciated.
Old Aug 16, 2021 | 06:39 PM
raphman's Avatar
'16 C63s
There are only 2 settings for the adjustable exhaust: on and off; either the flaps are positioned to make more noise or they're not.
​​​When you set the car to Sport+ or Race, it activates the louder exhaust. Obviously, this can also be done in any drive mode by using the exhaust toggle button on the center console.
There will be no exhaust sound difference between Spot+ and race. The only audible difference may be in shifting speed and how long the car holds a gear.
Old Aug 16, 2021 | 06:50 PM
boosted20v's Avatar
2020 AMG GT63s
: the tech said that there is no sound difference between sport+ and race.
facts.
