Colling of turbos
However when the car is being drove in comfort mode even for long distances or long time. It turns its self off when stopping at junctions roundabouts traffic lights
So is this damageing the turbos?????
As for less wear, every time an engine is not running is considered no wear in parts.
As for saving the environment, try stand behind the car while it idling and tell me you don’t smell anything. Btw, this is just a discussion not an argument.
. I appreciate the silence at times when it activates, our engines idle loudly-even when fully on the brakes. Conversely, it can be a real P.I.T.A. Pulling up to a stop sign?- engine stops. Pulling up to a red light that turns green the instant you stop?- engine is off. Possibly the worst part about those 2 situations is that there is then a lag between the engine restarting and the clutch engaging. Its enough to make taking off a rough jerk of an experience, or to leave you sitting still while people around you are going.Glide mode I also have mixed feelings on.....
On long highway stretches it has the propensity to be useful, pretty annoying on city streets. I like it on long, rolling hilly highways (obviously), and it can certaibly be handy if cars are braking ahead of you. What i can't stand is when you come off of the gas for 0.25 seconds on the highway, and it pops into neutral. It upsets the car for nothing, and it can't possibly be good from a wear perspective. I guess what I really miss is having a manual trans, and being able to select neutral or any other gear non sequentially, on a whim. The best ecu is your brain- you know what gear you will need 200 feet ahead based on what you see. An ecu only knows what you're telling it right NOW.
Good info on cooling on this thread. Have had similar questions myself for a while now. In the past I made a point to turn off start/stop if my temps were on the higher end (>210F). I probably still will but good to know cooling is still occurring when the engine stops.
