C63/C63S AMG
Several Error Messages After Less Than 400 Miles?
Old Sep 27, 2021 | 11:20 AM
FLC63s's Avatar
AMG C63s Sedan , AMG C43 , AMG G63 , GLK 250
Originally Posted by RavenM6
Apparently the ASR (same as Renntech) exhaust flap module was causing some sort of conflict. I had installed it and it ran fine for a couple of days without any incident so I didn’t think the ASR was related. They unplugged and replugged the module back, and cleared all the codes. So hopefully it’s been permanently resolved as the module is working just fine and the codes haven’t returned. Thankfully they didn’t charge me and covered the fix under warranty.
Why would you name Renntech, vs what the actual brand is/was ?? (was it a renntech item?)
So when you installed your ASR, did you unplug your battery ? ( seems like NO )
Since there are sub systems in the car that monitor a ton of other crap, anytime you introduce another electrical element, its almost 100% to disconnect the battery, as any change in resistance and draw, with start to freak the car out, if it hasnt adapted for it.
I have not heard nor seen this problem prior ( FYI)
Old Sep 27, 2021 | 09:24 PM
RavenM6's Avatar
2010 BMW E63 M6 Coupe 2023 AMG C63s Coupe 2005 YZF-R1
Renntech doesn’t make their modules, there’s is a private brand ASR module. If you’re a US buyer and try to buy from ASR directly, they refer you to Renntech USA. The YouTube install video I watched didn’t mention disconnecting the battery so maybe that’s where the issue arose from.
Old Sep 27, 2021 | 09:30 PM
FLC63s's Avatar
Ok , and ?
want to respond to the rest if the question ??
Old Sep 27, 2021 | 09:32 PM
RavenM6's Avatar
Ok , and ?
Yes, see edit.
Old Sep 28, 2021 | 09:54 AM
FromV4_to_C63's Avatar
2021 AMG C63 Coupe
Things happen bro , it will be fine.
