Traction Issues
I’m having issues getting my 2017 C63 S Coupe to launch properly..
The wheel spin is much more than I anticipated and I’m losing Traffic Light Grand Prix’ left and right :’(
I often see posts of people with bone stock C63’s that run 1/4 in under 12 seconds which I assume needs a near perfect hook at launch.. which I can’t get for some reason.
Because of this lack of traction, I’m also hesitant to tune to vehicle since I’m not able to utilize all the initial power and torque anyways.
Am I able to swap my 285 Michelin PS4S to 295 on my stock rims?
I also often see articles about improving suspensions which could help.. but I’m very new to making mods to cars and even posting on forums.. so any and all help is greatly appreciated!
Being that you have a coupe, it is lighter in the rear as well then the sedan, so you will spin more if you just stomp it.
And over the years, I’ve been learning to accelerate just enough that it barely slips.. but it doesn’t seem to quite reach the usually advertised speeds of 0-60.. which if why I feel like I may do something wrong or missing something. I’ve recently come to see how drastic the difference was after driving an AWD car with a V6 twin turbo and the torque at launch felt like night and day.
I figured there must be other things I can change with the car to help me reach that perfect launch.. which maybe widening my rear 285’s to 295 may do if it’s safe to do so.
Is there any way to get more weight into the rear as well without the need to fill the trunk with sand bags? Or do I really need to light the tires up every time I want a good launch?
Tire pressure is also important to get maximum contact patch. The pressures on the door sticker are too high, and you essentially just end up rolling on the center of the tire, effectively narrowing your tire. The proper tire pressures are inside the fuel door. They are 32psi in the rear for my 2019 coupe. You may also get a better hookup if you put the suspension in comfort mode, so there is more weight shifting to the rear and the initial suspension compression softens the blow to the tires.
Lastly, AMG set the launch rpm too high for Race Start, and unfortunately in the PFL you can't change it. In the FL (2019+) you can adjust the launch rpm using the shift paddles in 100 rpm increments. The instructor at the AMG Driving Academy told us to lower it by 300 rpm, otherwise you'll just have wheel spin and it does work. He even lowered it when he demonstrated Race Start with a GT63S with 4 people in the car. Much better hookup at slightly lower rpm.
One last thing is that I’ve noticed my vehicle is cambered a small bit which I’m not sure if it comes factory like this or if it’s from the previous owner since I got this certified pre-owned.
Because of this, I was told I couldn’t get warranty on my tires since it’ll be uneven wearing and it also made me wonder if this contributed to my lack of grip.
Should I angle it to make flat contact with the road? Or will that be a big mistake?
Yes, camber is normal. There's more camber in the front than in the rear. It's for cornering and yes your tires will wear more on the inside as a result of it. They get pressed down as the suspension compresses in the rear, so with proper tire pressure you'll get full contact patch during a launch.
EDIT: But if the previous owner changed the suspension, then all bets are off. Most aftermarket suspension aren't really good. They throw off the balance of the car and are mainly done for aesthetics (lowering the car).
Thanks!
I guess I really just need to wait for summer to really try them!
Sucks being in Southern Ontario so warmer temperatures don’t last too long.
Thanks for the help!
Trust me and just buy 305 30 20 ps4 all seasons. The compound is soft and sticky and will hook up(tuned) in 3rd gear in 35 degree temps. Second gear will hook around 55 and there is no street tire on the planet that will hook in first gear tuned.
