C63/C63S AMG
Tire width
Old Dec 16, 2021 | 12:49 PM
birch94!'s Avatar
c63s sedan
Tire width
Hey needing new tires on my C63S sedan. I’m wanting to go wider with the tires. Just wondering what size tires people are riding on with their stock 19inch rims?
Old Dec 16, 2021 | 09:02 PM
anerbe's Avatar
C63S past: E90 M3 6M, w211 E55
255/35 and 275/35 are the safest bet. I've had a great experience with my 255/35R19 and 275/35R19 Pirelli PZ4's.
Some get away with a next step wider (265/285), but you will probably need to lower the aspect ratio, which will make your sidewall even more narrow. Since I daily drive it, I didn't want to worry more regarding road hazards with the narrower sidewalls. If it was more a weekend ride, I would have probably gone 265/285 30
Old Dec 17, 2021 | 11:16 PM
C3504matic's Avatar
2015 C63S ,DME Tune, KW Has ,Kmac Bushings,BC Forged wheels,Gt Rotors,Porterfield R4S,Modal Intake
285 will fit in the rear on stock rims 255 up front
Old Dec 18, 2021 | 08:23 PM
SLC63's Avatar
C63
Depends on what wheels you are running and offset. I moved up to a 285 rear PS4 and it was a huge improvement in traction. My tire shop is going to order me a 295 when I wear through these and see if we can get them to fit.
Old Dec 19, 2021 | 12:16 PM
Struth's Avatar
AMG C63s
I have 305 on the rear and 285 on the front of my C63s Coupe slight scrub on the back when hitting a dip in the road but causing no issues
Old Dec 19, 2021 | 02:09 PM
kfehling's Avatar
2015 C63 AMG S Edition 1, 2021 GLS63, 2020 McLaren 600LT Spider
It also depends on the tires. There can be as much as an inch difference in a 295 width tire from different brands and even within brands. Check the tire specs before you buy.
Kurt
Old Dec 24, 2021 | 05:14 PM
Umeezy's Avatar
2016 C63s
255/35/19 front 275/35/19 rear
Old Dec 25, 2021 | 09:28 AM
cornerjunkie's Avatar
none
what size are you running up front?
