C63/C63S AMG
W205 Carbon Ceramic Brakes Part Number
Old Dec 29, 2021 | 04:44 PM
StormHawk's Avatar
C63S
Question W205 Carbon Ceramic Brakes Part Number
Hello, I am trying to see if I can order the carbon ceramic brakes through the dealer, and they require the part number to look it up. I understand that the front rotors are the only ceramic component in the kit. I am still interested in the gold calipers and the entire kit though. I was wondering if anyone has the part numbers for the rotors, pads, and calipers for the front and rear, of a 2019+ W205 coupe. I can't find it anywhere. Thank you.
Old Dec 30, 2021 | 07:05 AM
zipzap's Avatar
W205 C63s 2015
Hay mate , send me a PM with your VIN and I’ll look it up on the MB parts
Old Dec 30, 2021 | 05:32 PM
StormHawk's Avatar
C63S
Appreciate it, I have PMed you it.
Old Dec 30, 2021 | 07:02 PM
CarHol's Avatar
MB
use e63 vin that has carbon brakes WDDZH8KBXLA757795 posted here on forum
Old Dec 31, 2021 | 09:28 AM
jopsis_c63s's Avatar
C63s Estate
Hello!
https://www.kunzmann.de/shop/en/orig...c-original.htm
For rear you need e63 references.
Rear axle: – carbon ceramic discs 360×32 – A2314230612, A2314230712 – single pot Brembo calipers TRW with a floating bracket – A2314231181, A2314231281, A2314230206 – brake pads for carbon ceramics – A0004203202
Old Jan 1, 2022 | 09:25 PM
StormHawk's Avatar
C63S
Originally Posted by jopsis_c63s
Hello!
I appreciate it. I believe the website you linked for the front brakes only list the part numbers for the rotors. What about the front calipers and brake pads?
Old Jan 6, 2022 | 08:19 AM
FDNewbie's Avatar
'17 AMG S63 Convertible, '17 AMG C63S Edition 1 Coupe
No affiliation:
1) C-class brake setup: https://www.ebay.com/itm/20296362811...item2f41933053. States you can add the rear rotors for $4k
2) E-class brake setup from same seller: https://www.ebay.com/itm/Mercedes-Ge...-/201918989490
3) Parts Numbers: This is UNVERIFIED. So I can't be held responsible if some of them are wrong, but I've been assured the part #s are correct.
- Caliper #231-423-11-81
- Caliper #231-423-12-81
- Rotor #231-423-07-12
- Rotor #231-423-06-12
- Caliper Mount (need 2) #231-423-02-06
- Brake Pads #007-420-91-20
Kindly share if you're verified the part #s are right, or any corrections you find.
Thanks!
