Stock turbo hp limitations
Curious if anyone has any info on the stock turbo limitations or maximums of stage 2. I’m about to dyno on 101 octane, modalworks intakes, and catless 3.5in downpipes, I previously made 540whp/627tq on 91oct without intakes. I’m curious if others have dynod with similar setups on similar octane. Any guesses on what I should expect?
I dont think anyone can give you a hard, real world turbo limit but ultimately its the compressor efficiency map that will matter. Not seen one for the stock turbos.
I'd bet intakes net you 15+ more whp in top end, guessing.
*****I'm having my car tested at the Dyno tomorrow and my car still has the stock turbos, but a new tune, and BMS Intake system. I had the car tested a couple of weeks back bone stock, with the BMS intakes, and no tune. Checking to see how much the tune was worth HP and TQ wise as well as to assess fuel trims, EGT, AFR, etc.. before I put the new turbos on, and have a tune made up to optimize it all.
Looking forward to your results. That number seems feasible with the addition of 101 octane + intakes on a solid tune. Either way peak power will be around 5k-5.5k on stock turbos and you will see a dropoff topend since they run out of breathe. No real way around it unless you upgrade them.
