C63 Common problems?
tldr:Check coolant level lights, coolant reservoir is full. How should I action this
Thanks!
Thanks!
The proper method is using a special tool that seals the system and uses vacuum to literally suck in the coolant with no air pockets being formed. No way you get the air out by squeezing hoses or "burping" or whatever old school method worked on some old car back in the olden days. The water pumps are different now and cavitate easily and don't self prime like old school tech did. There is also the possibility that your system doesn't hold pressure properly, due to faulty cap(s), or less likely a blown head gasket, etc.. The system can be pressure checked for leaks with the same or similar tool used to refill the system, assuming the tool is used properly and the adapter for the tool is installed properly, is the correct size, etc..
Anyway, stuff to think about and check. Good luck.
appreciate the time you took for your reply 🤝🏻😁
