C63/C63S AMG
Low pressure fuel pump
Old Aug 23, 2022 | 02:21 PM
SkiZzy's Avatar
c63s
I’m going to be running the eurocharge stage 2 e30 flex fuel tune. Do I need an upgraded low pressure pump and if so, what pump should I get?
Old Aug 23, 2022 | 09:12 PM
SJGetsome's Avatar
W205 C63 AMG Coupe
What did Eurocharged tell you when you were ordering your tune?
I expect that there is some room built in to the stock pump, but it's probably a car-by-car thing that will need to be logged to make sure your LPFP is keeping the pressure to the HPFP high enough. At least that's how it was on my 335i (some cars could run a higher ethanol blend than others before needing to upgrade the LPFP).
Old Aug 23, 2022 | 09:15 PM
SkiZzy's Avatar
c63s
Eurocharge said the pump would be fine to e30 but wanted to be safe.
