C63/C63S AMG
My C63s Estate on 20s
Old Nov 2, 2022 | 12:36 PM
Belong's Avatar
W205 C63S T
delete
Old Nov 2, 2022 | 02:44 PM
mars c63s's Avatar
C63s
Nice 👍
It looks like it's dropped as well. Is it?
Old Nov 2, 2022 | 08:00 PM
Belong's Avatar
W205 C63S T
Originally Posted by mars c63s
Nice 👍
Yes its on Eibach springs, still thinking the suspension on the w205 AMG is hard as fck...
Old Nov 3, 2022 | 06:10 AM
mars c63s's Avatar
C63s
Yes, very hard, but very good for track use.
How is it on the Eibachs? With that drop, lower tirewall, and wider offset, what's your feedback?
Old Nov 3, 2022 | 06:27 AM
Belong's Avatar
W205 C63S T
To be honest ,the eibachs has made it a bit softer... but now that im used to it , it still think the susp is way to hard on the C63.
The 20" with 255 30 20 , 285 30 sure dont help, but the car is alot more stable on higher speeds where i found the car above 130mph floaty on the oem wheels.
Im gonna make my own set of wheels again over this winter and these will be forged, so lets see what that brings then...
performance stick with the 19s... looks --> 20s
Old Nov 6, 2022 | 11:33 PM
mjcw77's Avatar
2016 C63s Estate Edition 1
How on earth did you fit 285's on the rear? I have 265 rear (265, 30, 20 Pirelli P Zeros) and might be able to squeeze 275 but 285?!?!? do tell how you managed that...
My wagon / estate on 20" ZITO ZF01's
Old Nov 7, 2022 | 07:13 AM
Belong's Avatar
W205 C63S T
Weve had contact before on instagram i think ( EstorilV10 )
my car is slightly higher then yours... and my rear wheels are a bit aggresiver then yours.. and its on the edge imo whats still acceptable offset wise... But yes the 285 is on there , ideal setup i would drive would be 245 35 20 fronts and 285 30 rears.. the 255 30 are a bit to skinny/strechted look for me..
Im going with some custom ADV1
Old Nov 7, 2022 | 10:45 AM
Pieter Schepers's Avatar
E55 AMG Wagon
How are the lowering springs in terms of comfort. I have a PF wich is even harder than yours stock.
What diffuser are you running?
Old Nov 7, 2022 | 11:53 AM
Belong's Avatar
W205 C63S T
Mine is also PF, im just running FL grille and diffusor with the bigger tipps
