C63/C63S AMG
Tyre pressure sensor
Old Feb 21, 2023 | 08:59 AM
japamg's Avatar
Final Edition C63s / RS3 Sportback
Hi guys
So I will be changing my wheels shortly. Wondering if you fit new pressure sensors you’ll need to reprogram them with xentry or just an easy adjustment through the car menu?
Thanks!
Old Feb 21, 2023 | 03:40 PM
MaverickC43's Avatar
Amg C43
I thought the only issue is keeping them in the same spot R/L F/B
Old Feb 21, 2023 | 04:03 PM
japamg's Avatar
So they will adapt automatically? No adjustment needed?
Old Feb 22, 2023 | 12:39 AM
Iridium.C63s's Avatar
16' C63s, 22' RAM 1500
you can add them to any tire regardless of position and they will adapt automatically. I just installed sensors to my new wheels recently. Ill add the site were I got OE ones for dirt cheap.
https://www.tpms.com/Schrader-33700-...rcedesbenz.htm
Old Feb 22, 2023 | 02:34 AM
japamg's Avatar
Thanks!
Old Feb 22, 2023 | 02:56 PM
superswiss's Avatar
2019 C63CS
As said above. You just need to go into the service menu and set the new pressures as reference. It will detect the sensor at each location and store the tire pressure. My wheels have changed sides multiple times whenever I get a new set of tires, so the wheel sensors move and the system learns their new position after resetting TPMS, showing the correct pressure at each corner.
There's an antenna in each wheel well and based on signal strengths and latency it knows which sensor is where.
