C63/C63S AMG
19' C63 S Transmission Oil Change question
Old Feb 21, 2023 | 03:44 PM
Mustafoinc's Avatar
2019 C63S.......2016 GLE 63.........2008 S63
I am getting my transmission oil changed (but not from Mercedes) and wanted to know what parts Mercedes recommends I change, so far I have this:
Drain Plug - 725-271-18-01 https://www.mbpartscenter.com/oem-pa...lug-7252711801
Transmission Oil Pan Gasket - 725-271-53-00-64 https://www.mbpartscenter.com/oem-pa...t-725271530064
Trans Pan - 725-270-31-14 https://www.mbpartscenter.com/oem-pa...pan-7252703114
But at the bottom of any of these pages it says "Also Purchased" do I need the other stuff also?
The other Stuff:
Drain Plug - 725-271-18-01 https://www.mbpartscenter.com/oem-pa...VkIFByb2R1Y3Rz
Air Filter - 177-094-01-00-64 https://www.mbpartscenter.com/oem-pa...VkIFByb2R1Y3Rz
As you can tell I don't know to much about Transmission oil but I watched a few videos to get an idea of what stuff I need to buy (don't want to have the mechanic say well you needed this part or that part). So any help is appreciated. My Goal is to get the parts that Mercedes recommends I change and give these to the mechanic.
2019 C63 S - 74k miles
Old Feb 22, 2023 | 12:18 AM
Iridium.C63s's Avatar
16' C63s, 22' RAM 1500
Hopefully this helps. I bought my kit from fcpeuro. came with everything I needed to change out the transmission oil.
https://www.fcpeuro.com/products/mer...tosin-7229late
you can also order the parts individually.
I change my transmission oil every 30k miles btw its a very easy job to do so yourself!
Old Feb 22, 2023 | 08:59 AM
Sazabi's Avatar
2019 C63s
The 2019 and the 2016 C63's have different Transmissions, so I'm not sure that the listed kit will work. Just a heads up.
Old Feb 22, 2023 | 09:02 AM
Sazabi's Avatar
2019 C63s
The other Stuff:
Those Air Filters look like they are for the engines in the E63, etc, you dont have to worry about them, and for the drain plug you posted the same parts number, so only get one.
Old Feb 22, 2023 | 10:47 AM
either way they have a kit for the 9 speed also.
Old Feb 23, 2023 | 12:48 AM
Mustafoinc's Avatar
Yep exactly! I gave them the last 8 of my vin and boom! Thank you for taking a time out to respond to me It was very helpful!!
Old Feb 23, 2023 | 12:50 AM
Mustafoinc's Avatar
Oh gee thanks for mentioning this or I'd probably be paying restocking fees lol
