C63/C63S AMG
Weistec intake ... worth it???
Old May 24, 2023 | 11:27 AM
Belong's Avatar
W205 C63S T
Any owners here of the Weistec intake for the m177 here? thoughts???
Old May 24, 2023 | 02:15 PM
vodand12's Avatar
'21 C63S, '24 GLE53
From a performance standpoint, it is not worth the money.
You're getting a marginal hp increase on the very top end; you will never notice it.
It's mainly a cosmetic/sound modification. It does look good, though.
Old May 24, 2023 | 04:13 PM
noremaC's Avatar
17 C63S Coupe PTG1000
It depends on your mods. If you're running larger turbos, more boost, higher octane etc. then you should definitely be looking at upgraded intakes. You're sucking in more air....the stock intakes were not designed to support that.
I am running PTG intakes (other vendors have similar molds) and there is definitely a performance increase. I also have numerous power mods, so take it fwiw.
One thing I will say - I originally ran modalwork intakes and the sound was incredible. The trouble was, they were triggering a soft code and pulling power (apparently they have harness extenders as a fix for that), so I couldn't run them for long.
The closed intake systems really don't sound any louder than stock but you have the benefit of lower IATs over open systems.
Old May 26, 2023 | 08:43 PM
Spicywolff's Avatar
18 c63 s sedan
For the $$ to HP ratio a tune is the best bet. If you tune and add downpipes even more so. After that it’s not very cost effective
Old May 27, 2023 | 01:21 AM
SilverBullet18's Avatar
C450,GLC 63,VW GTI
bms filters with an airbox spacer will get you there
Old May 27, 2023 | 04:48 AM
Belong's Avatar
W205 C63S T
Im 770 bhp on bigger turbos... with enclosed intake... but i can buy a Weistec intake kit for a good price of a friend of mine whos selling his car..
I had some trouble with a bad fiting of the air intake pressure sensors on the rear of the box... it threw the crankcrase pressure P1CE700 and P1CE800 code.. which i believe is soft limp or whatever.. but it did pull power... AM I RIGHT HERE?
Im stage 3 with Hybrids...
Im enclosed now, with filters..
