C63/C63S AMG
C63 loss of power 2017 PLEASE HELP
Old Jun 13, 2023 | 04:09 PM
rekiloz1's Avatar
c63
Hey everyone, I have 2017 c63s running stage2 catless downpipe. After the exits the cold start cycle it runs perfect, once it warms up a little it starts popping from the right (passenger side exhaust) im including the video so you can hear. Once it warms up more it starts popping non stop. When i shift the car into drive it stops. Today i went on a dyno and car only pushes 383HP. Xentry diagnostic throws code for a leak in the air intake system (bank2). Ran smoke test, did all the other tests and there is no leak. Car is not in soft limp mode since i can see the boost bar moving up and down. I heard there were problems with exhaust valves, mufflers are cut off and programmed out, H pipe valve is welded and also programmed out. Doesnt throw any cel or any codes other than that. Can someone please help me out with this because its driving me nuts
Old Jun 14, 2023 | 12:38 AM
jopsis_c63s's Avatar
C63s Estate
First of all I would replace the ignition coils and spark Plugs
