C63/C63S AMG
Black Friday Sales! Turbos, intakes, manifolds, cooling, methanol and more
Old Nov 24, 2023 | 10:09 AM
ModalWorks's Avatar
SPONSOR
W205 C63
All C63 products are discounted now through December 1st, while supplies last
C63 PRODUCTS
Old Nov 24, 2023 | 07:03 PM
Spicywolff's Avatar
18 c63 s sedan
Very nice. Super tempted to pick up the trans cooler. 250F at track days is unacceptable.
Old Nov 24, 2023 | 09:27 PM
SJGetsome's Avatar
W205 C63 AMG Coupe
Have any dyno charts of the turbos on straight pump 93 octane, with the stock fuel system & no meth?
Old Nov 25, 2023 | 09:31 AM
ModalWorks's Avatar
SPONSOR
W205 C63
The power levels will be highly tuner dependent, our motors run out of fuel based on how much boost is applied, so theoretically a tuner can run lower boost with more timing to make up power.
When shopping for a turbo, the top considerations should be spool characteristics and ultimate flow capability.
With sufficient fueling we are able to maintain 35+psi without maxing out the turbo. With complete OEM fueling on 93 we typically see 26-29psi being the max, (between 700-730whp based on other mods).
With that being said here is a dyno of a complete stock fueling car, I believe running 27psi target. They opted to limit the torque considerably as you can see it flatten out just beyond 3,500rpm.
With methanol injection acting as a secondary fuel source we can up the boost substantially. The graph below is our shop car (we were having wastegate issues hence the waves). Notice the power/torque level at 4krpm compared to other turbos. These spool very quickly while others take another 1k rpm+ to reach full boost.
Old Nov 25, 2023 | 09:33 AM
ModalWorks's Avatar
SPONSOR
W205 C63
let’s lock it in! We have 5 sets left
Old Nov 27, 2023 | 02:28 AM
Gencheezy's Avatar
2015 C63s Edition 1 Sedan
You 100% need it! really does its job. DM me on Instagram @gencheezy I can send you some images showing how great it works. Spicywolff
Old Nov 27, 2023 | 07:15 AM
Spicywolff's Avatar
18 c63 s sedan
have you used it at HPDE and track use? That’s where
im having issues. I have to hit 2-3 hard laps in race mode and it’s climbing past 230 easily.
