C63/C63S AMG
C63S - Mod List
Old Jan 24, 2024 | 07:01 PM
a63mrk's Avatar
W205 C63S
C63S - Mod List
Purchased a W205 C63S PRE FACELIFT and am wondering what are some first mods. Example, Down pipes intakes etc? Also curious about exhaust mods? Do not want to buy an entire new exhaust and want a more “muscley” deep sound like the OG W204. Thanks.
Old Jan 25, 2024 | 06:43 AM
noremaC's Avatar
17 C63S Coupe PTG1000
Your basic “stage 2” setup would be downpipes, intakes and a tune. Look at @ModalWorks for intakes and downpipes - they have proven products at very reasonable prices.
From a tuning perspective, I would consider MPE Paris. You are going to get “street tuning” meaning you will data log on the street and they will revise/optimize (they also have great customer service via WhatsApp). It’s a little more expensive because you need to buy HPTuners MPVI3 cable and credits, but it beats off the shelf (OTS) tunes from a performance and drive ability perspective. You can always save a few bucks and buy an OTS tune as well.
If you have the OEM performance exhaust, you don’t really need to touch anything from an exhaust perspective as it’s really good for the factory, other than doing catless downpipes. You can also find catted downpipe options that flow better stock.
Old Jan 25, 2024 | 07:49 AM
a63mrk's Avatar
W205 C63S
thank you for the input. Do you have any recommendations for catless/catted downpipes? Running the car stock for now. Just looking for that mean sound don’t really care for extra power right now. Should I go catless or catted?
Old Jan 26, 2024 | 06:21 PM
LessIsMore's Avatar
2017 AMG C63
Mod 1 - JB4
Mod 2 - intake (modal works)
Mod 3 - stickier/wider tires (PS4S)
Mod 4 - downpipe if you like it LOUD all the time, or start beefing up fuel system for more boost or bigger turbos.
I would not waste money on expensive catback systems or CF intakes, unless you really need to show off.
Old Jan 27, 2024 | 04:55 AM
LR63s's Avatar
C63s W205
did you switch over from ptg to mpe?
Old Jan 28, 2024 | 09:07 AM
noremaC's Avatar
you’re most likely getting a check engine light when replacing the stock primary downpipes/cats with catless or high flow catted DPs, so you’re going to need a tune.
catless is going to smell a bit, so as long as you’re okay with that, I would say catless > catted for the best sound. Modalworks has both options at reasonable prices. MW has 200cell cats.
something else you may want to consider is Renntech EVM - keeps your valves open @ 100% open position when the exhaust button is enabled. Read up about the module to get more info on the stock valve operation. This paired with catless DPs will get you the best sound.
Old Jan 28, 2024 | 10:14 AM
dlefty's Avatar
/////PRO
I think a good reliable start:
BMC or K&N air filters in stock airboxes
PTG ECU tune
Downpipes-whatever your desire, just make sure good quality stainless of appropriate gauge.
