Sudden rattelig/klunking
at lower speeds it sounded more like klunking and flapping. I checked my undertray and wheel arches - all good. I also tried pulling the drive shaft to listen for looseness - nothing odd there.
After I continue and test it at speed.
gears are working good, no vibrations or abnormalities while driving, only this weird noice.
When accelerating it is almost like everything tightens up and it dosapears until i let off the accelerator. Most noticable between 20kmh to 10-120. At higher speeds it is there, but nothing too dramatic.
The noice seem to be in/under the midconsole between the seats and also on the right behind the glove compartment.
Video attached at about 120km/h
https://vimeo.com/928429276
EDIT: one more at 40-60kmh
https://vimeo.com/928518826
Surprised it was the bearing and not the rubber bushing as it created a lot of noice, but apparently the bearing is fully capable to make these noices by itself. Even with a healthy rubber bushing.
for others that might run into it.
Car milage was 125.000km
Part numbers
Mount with rubber insert: 2054103302
Bearing: 008981512564 or 0089815125
