C63/C63S AMG
C63s C205 radpack
Old May 25, 2024 | 07:15 AM
MBEnt63's Avatar
c63s
C63s C205 radpack
Hey guys, I know that the c63s got 6 different radiators, and I want to get a complete radiator pack for my c63, but the issue is there isnt much info on the part numbers. If someone can help and tell me if these are the correct ones I'll be thankful.
Oil Cooler - Mercedes-Benz (099-500-00-01)
Automatic Transmission Oil Cooler - Mercedes-Benz (099-500-19-00)
Mercedes-Benz Genuine Water Cooler Radiator 0995005403
Mercedes-Benz Genuine Auxillary radiator (left and right) 0995005903
Heat exchanger for turbos which I couldn't find the part number for.
in case if you're wondering Why I need all these it's cause of a rebuild that I'll be doing in 2 months.
Old Jun 12, 2024 | 02:24 PM
hhyndoy's Avatar
C63S Edition 1
There are two heat exchangers, one that exchanges transmission fluid temp with coolant and one that dpes the same thing for engine oil.
the transmission one - that is also a part of the intercooler loop. I think this is where you mixed up turbo cooler.
0995005903 are the auxilary radiators that sit in front of each front wheel. Same part number for both sides as they can be fliped to fit oposite sides.
0995000454 the front most radiator in the pack. This one belongs to the transmission/intercooler circuit.
1331880001 Is the engine oil/coolant heat exchanger, similar to 099-500-19-00, but does not have a thermostat on it like the transmission exchanger does.
Then as you mentioned, the engine coolant radiator, that sits in the back of the cooler pack. 0995005403
and
099-500-00-01 engine oil cooler that lays flat in front of the radiator pack in the middle down low.
if you want to understand the transmission/intercooler circuit you can read my troubleshooting journey and how I solved my overheating problem in the following😁 I ended up adding an additional oil cooler only dedicated to the transmission fluid.
https://mbworld.org/forums/c63-c63s-...erheating.html
