C63/C63S AMG
P167085 and P152700 codes
Old Nov 5, 2024 | 10:53 AM
sreit's Avatar
2021 Mercedes-AMG C63 Coupe
The turbos on my 2021 C63 (M117.980 engine) keep dying. Shutting the car off and restarting fixes it for a while but then it happens again.
Finally got some DTCs:
P152700: "The check valve of the evaporative emission control system for cylinder bank 2 (at partial load) is jammed open."
P167085 "Calibration of the torque curve of the control unit has a malfunction. There is a signal above the permissible limit value."
Anyone have a clue how to resolve these?
Is the boost pressure solenoid possibly the problem? If so, is there a way to test it?
Thanks for any clues anyone can provide.
Old Jan 28, 2026 | 11:33 AM
thiccslav's Avatar
Having same issue
Hi, I’m currently having the same issue as of Jan 1 2026. Did you manage to solve the issue? I’m scratching my head at this and even my mechanic has no idea what’s happening. I replaced the purge valves and still have the code and loss of boost.
please let me know 🙏🏼
Old Jan 28, 2026 | 12:06 PM
sreit's Avatar
Yes, I did. I got a little help from JustAnswer.com. Sometimes you get a very knowledgeable tech through that service.
I got many other codes before contacting them though: At one point I got P152700, P237700 and P012D00. A few weeks later I got just P012D00 and P012B2B.
A month after that it was P152700 and P012D00.
The changing codes were very confusing.
In the end, the P152700 code ("The check valve of the evaporative emission control system for cylinder bank 2 (at partial load) is jammed open") seemed to be the one that explained the problem because I replaced the evap purge line (which has a check valve in it), and the problem hasn't reoccurred in the 10 months since.
The part number for the evap purge line (left side) on my W205 C63 was A1770105308.
FWIW the Mercedes Xentry Parts Information db has been pretty helpful, and it's a "relatively" inexpensive subscription (at least compared to the other Xentry stuff).
Which purge valves did you replace?
Old Jan 28, 2026 | 12:08 PM
thiccslav's Avatar
I replaced both purge valves but not the lines. I think that’s what I’m going to do next. I’m not going to lie, I think I saw ur thread on just answer with Lou. I think you saved my hind brother. Thanks so much for your prompt response 🙏🏼🙏🏼🙏🏼
Old Jan 28, 2026 | 12:22 PM
C63s_Jack's Avatar
AMG C63s Coupe
Are yours cars sw-tuned ?
thiccslav's Avatar
stock tune right now. I want to tune it and having this issue.
Old Jan 28, 2026 | 12:44 PM
C63s_Jack's Avatar
AMG C63s Coupe
stock tune means OEM ? ( i think so)
I would think carefully about the tuning.
Personally, I'm not a fan of it.
Do you have a pre-facelift or facelift model?
Old Jan 28, 2026 | 01:55 PM
thiccslav's Avatar
Got a 2019 so it’s a facelift model. The tuning is better for the far. The only things I would do is upgrade the whole suspension and tune it to stage 2. But I first have to fix the issue that’s prevalent when the car stock/OEM
