C63/C63S AMG
265/35 & 285/35 tire pictures
Old Nov 25, 2024 | 12:50 AM
talkr21's Avatar
2017 C63
Hey guys! I have a stock sedan c63 non s and i currently have 255/35 & 275/35 tires. I was reading through some posts and a lot of people recommend 265 & 285. I have one question which is will i get any rubbing? And can yall share some pictures of your setups?
Old Nov 25, 2024 | 08:49 AM
Roysup's Avatar
2018 C63S AMG Coupe, 2019 Jaguar F-Pace SVR
I am running Michelin PS4S 295/30/20 in the rear, and 265/30/19 in the front with H&R lowering springs and KMac camber bushings... no rubbing at all.
Old Nov 26, 2024 | 11:54 PM
ChargedMB's Avatar
how do you like the Kmac camber bushings? Looking at different options for camber kits and there aren’t many options for the “S” and Coupe combo it seems
Old Nov 27, 2024 | 01:40 AM
Roysup's Avatar
The Kmac bushings work perfectly to adjust the camber properly. Absolutely zero wear on the inside edge of the tires now.
Old Nov 27, 2024 | 02:28 AM
superswiss's Avatar
2019 C63CS
OP has a sedan. The coupe accommodates wider wheels/tires. I have to say that front wheel looks very awkward, though w/o camber and tucked in so far. The fender sticks out way past the wheel at least from this angle. What do you have now? 0 degree camber? That's fine for straight line driving, but not if you like to corner. Definitely lost some aggression on the front. The rear looks fine.
Old Nov 27, 2024 | 03:08 AM
Roysup's Avatar
"0 degrees camber" ... Wow. Yep, you got it. 🤦‍♀️
Old Nov 27, 2024 | 05:03 AM
mokawop's Avatar
c450
Are you lowered? Spacers? You will be fine normal ride height. If lowered the 265 front will slightly rub top of fender when you are 2 wheeling out of driveways or lots.
