Memory seats
The previous owner replaced the original seats with the performance seats.
The problem I have is that the seat memory does not work. Everything else works, steering wheel memory and mirror memory. Seat heating and electric movement also work. The only thing that is not memorized is the seat position.
The fault occurs in the driver's and passenger's seats.
It's not that it's a problem of not knowing how to use the door buttons, since the steering wheel and the mirrors are memorized.
I have tried, as indicated in other threads, moving the seat to the end of its travel in all movements, but it has not worked.
I don't know if the memory worked or not before changing the seats.
The car is a 2016 C63S sedan.
Any help will be welcome.
The leg extension button works perfectly.
All seat movements can be done from the door buttons, except the headrest button, which the performance seats do not have.
It's the memory function of the seats that doesn't work. The other memories, steering wheel and mirrors do work.
I hope I can explain myself, I am with the translator, my english is very bad.
Check also when you move the seats all the way to the front and up, do they touch the sun visor at some point?
I suppose that when they changed the seats they didn't make the connection to the sensor correctly, I don't think they both broke down at the same time.
The performance seats have no headrest movement. When coding the seats in the car itself, an error occurred when reaching the point of coding the headrests.
At the official Mercedes service center, we coded the car's chassis number, indicating that it now has performance seats.
After this, we coded the performance seats without any problems. Now everything works perfectly.
I hope I've explained myself clearly.
