2019+ rear diff will fit 2017 c63s?
Can someone help me out with the part number for the rear diff for 2017 c63s edition 1 coupe (it's electronic locking diff)? Is it 2133506915 or 2053505607 or 2053504235?
Also, would 2018/2019 rear diff fit 2017 c63s as long as the gear ratio is 2.82? Or would even 3.06 ratio will fit also?
Last edited by Jimmy_c63s; Mar 4, 2025 at 04:04 AM. Reason: Forgot to mention the sensor
Diffs are identical but fact is later made facelift ones will whine less. Prefacelift diffs were known to fail and have bearing issues which cause the very slight whine as well as the actuator problems that cause the dash warnings.
I rebuilt my diff using a low km donor diff off a prefacelift a few years ago but I'm going to source a late facelift diff in future and put my Drexler unit in the facelift diff.
I have some posts I did on social media some time ago
https://www.instagram.com/p/CoNCMe0JZqR/
Just currently trying to source a used rear diff at a reasonable price.
I have noticed at low speeds under 10mph while making tight turns the rear axle is clunky at times. It sounds a lot like the Nismo LSD I have in the Z (if you didnt know what going on you would think the car is broken).
