C63/C63S AMG
Auto throttle blip when going into reverse gear?
Old Mar 3, 2025 | 08:13 PM
carzaddict's Avatar
2017 C63s converitble
I've only had the car for 3 days so I'm still getting used to it's quirks, but I've noticed the last 2 times on very cold starts, when I put it into reverse gear (with foot firmly on the brake) it will auto blip the throttle a little. Car doesn't move, but it's a little weird. I'll also mention that I wait for the revs to drop to idle before putting it into gear
Anyone else experience this? Normal?
Old Mar 4, 2025 | 12:05 AM
superswiss's Avatar
2019 C63CS
To be honest, I don't particularly recall in what situations it blips the throttle, but it definitely does at times. It all makes sense once you understand that this transmission doesn't have a torque converter and instead it has a wet clutch, so the throttle blips in various situations before clutch engagement. Car won't move until the clutch actually starts engaging. It's very much like driving a manual transmission and you blip the throttle to get the rpm in the right spot for clutch engagement. In this case it's the computer doing it for you.
Old Mar 4, 2025 | 09:02 AM
carzaddict's Avatar
That makes sense. I'm still trying to figure out the quirks of the car / transmission....what's normal behavior and what's not.
I'm understanding that it's also normal to feel like it's the trans is slipping when it's cold
Old Mar 4, 2025 | 10:18 AM
superswiss's Avatar
2019 C63CS
No, that's not normal. How cold are we talking and what year is your car? Model years older than 2019 have the older 7-speed transmission. It has different quirks. I have the new 9-speed, but even with the old 7-speed slippage is not normal as far as I know. With one exception, the 7-speed starts in 2nd gear when in Comfort mode, so that requires more slippage to get off the line. The new 9-speed always starts in 1st gear.
Old Mar 4, 2025 | 10:58 AM
carzaddict's Avatar
mine is a 2017 with the 7 speed. has 28k miles...car was PPI'ed, no flags raised about transmission or the way it drives (im assuming the tech drove it)
the garage temp was mid 40's...car hadnt been driven for 24 hours....it wasnt slipping bad, but yes it was in comfort. i need to find time to conduct a test in comfort vs sport.....its totally possible that it falls within the tolerance of allowed slippage in cold comfort (1500-2000k rpms)
Old Mar 4, 2025 | 12:42 PM
untamedd's Avatar
2019 AMG GT R
i had a 2017 with 100k kms but slippage was not a problem. Temps here get to -25 C and on those days it would just take a bit more gas to get going and shifts would be rough until it warmed up but that would be normal. Never experienced any slipping though.
Old Mar 4, 2025 | 03:02 PM
carzaddict's Avatar
thank you, perhaps i was using incorrect terms, it takes a bit more gas and shifts are rough. maybe its not slippage. I also dont have much experience driving manual to have experienced what true slippage is
Old Mar 4, 2025 | 08:10 PM
superswiss's Avatar
2019 C63CS
To be clear, there is always slippage in a clutch from a stop. The input and output side slip until they are both spinning at the same speed and the clutch is fully engaged. Undesired slippage would be if at any point you increase throttle input and hear the engine rpm increase without a corresponding increase in vehicle speed.
Having to give more throttle and things being a bit sluggish and jerky when everything is very cold isn't unusual. The fluid has to warm up and circulate and the pressure has to build up. At first the fluid may not flow just right so things may be a bit delayed and lazy until everything is warmed up.
Old Mar 4, 2025 | 09:49 PM
carzaddict's Avatar
You're right. Just went for a drive and things were lazy until they warmed up and then they smoothed out
Old Mar 13, 2025 | 01:31 AM
laurcrv's Avatar
yes mine always did this, like you can hear the exhaust roar a little bit for a slight moment,
also about the clutch slipping, it you mean from a stop it takes more throttle to move (the rpm raises but the car only moves after like 2k) it also is normal when cold. What I do is put the car in both drive and reverse first then I let don't touch the throttle and let it slowly start moving by itself. It seems to fix the issues or at least improve it, but from what ive seen it shouldnt be a problem either way
Old Mar 13, 2025 | 11:42 AM
carzaddict's Avatar
thanks for the input. im realizing as well that this seems normal. i wasnt using the correct terminology, its not slipping, but rather taking more revs to engage....but thats just at cold, once its warmed up, its back to normal
the auto blipping into reverse is a little weird. I end up pressing super hard in the brake just incase it lurches for whatever reason
