C63/C63S AMG
engine oil temp.
Old Mar 27, 2025 | 06:06 AM
Jimmy_c63s's Avatar
Didn't know it was a relatively common failure on this car?
Yeah sucks I know of 3 prefacelifts with them replaced but no facelift cars until I came across this thread
Old Mar 27, 2025 | 06:10 AM
W205C43PFL's Avatar
Ah a superseded part is available? Hoping the facelift one is at least more robust? Anyone verified if the facelift one can fit the pre-facelift one in anyway?
Old Mar 27, 2025 | 06:13 AM
W205C43PFL's Avatar
Were there certain environmental factors that we are aware of that cause theses to fail quicker other than factory design flaw/defect?
Old Mar 27, 2025 | 06:15 AM
Jimmy_c63s's Avatar
Good question man would like to know too.
Old Mar 27, 2025 | 06:21 AM
W205C43PFL's Avatar
For example, humidity, extreme cold or extreme hot but doesn't MB test these things prior to production?
Old Mar 27, 2025 | 09:42 AM
kcxbaek's Avatar
2019 c63 cabriolet
its my daily car,
i drive about 20-25miles to work, it take about 30min driving, my water temp level is always i slot higher from middle,
had low coolant warning, at first there was no leak.
leak from passenger side randomly.
went to mechanic and replaced radiator on passenger side,
my friends made fun of me after i said this but after that i felt improvement on performance.
low coolant warning again about 3days later,
they topped up coolant and told me to make sure leaking because they've done pressure test.
this symptom appeared twice, one before about 2000 miles ago,
im just little surprised that the car was running completely normal all the time expect fan running after like 5min. of driving all the time,
but as i search, it seems like its normal but annoying.
that's my whole story,
i really thought it's just sensor issue.
Old Mar 27, 2025 | 01:20 PM
  #32
kcxbaek's Avatar
2019 c63 cabriolet
, they were saying i need to change thermostat also, and they are quoted 4000. just got coolant tank cap replaced and pulled the car out went to different person. water pump seems ok BUT thermostat had to be replaced.
Old Mar 28, 2025 | 12:32 PM
  #33
kcxbaek's Avatar
2019 c63 cabriolet
looks like its a big project for replacing thermostat. im still curious why car did not throw engine lights or any symptoms.
File Type: mov
Old Mar 28, 2025 | 05:48 PM
  #34
Jimmy_c63s's Avatar
Looks wild but it's really just front bar off, middle aux cooler, radiator, fan, and once the intercoolers are off you've got access 25 torx size
Old Mar 29, 2025 | 08:29 PM
  #35
kcxbaek's Avatar
2019 c63 cabriolet
got thermostat replaced, no more annoying fan sound, car runs great! just picked up, and now parking sensors are off LOL
Old Mar 29, 2025 | 08:38 PM
  #36
W205C43PFL's Avatar
Great to hear the fan sound is gone, as for parking sensors, um loose cable?
Old Mar 29, 2025 | 10:32 PM
  #37
Jimmy_c63s's Avatar
Man that's really good to hear. Wondering what the max temps you'll see now? Keep us in the loop 🙂
Old Mar 29, 2025 | 11:28 PM
  #38
kcxbaek's Avatar
2019 c63 cabriolet
gonna go back Monday lol
Old Mar 29, 2025 | 11:30 PM
  #39
kcxbaek's Avatar
2019 c63 cabriolet
so max temp i saw was 213, went down to 210 in seconds. it runs between 205-210
Old Mar 29, 2025 | 11:31 PM
  #40
kcxbaek's Avatar
2019 c63 cabriolet
do you know where the cable is located? trying to see if its loose
Old Mar 30, 2025 | 12:05 AM
  #41
W205C43PFL's Avatar
I am wondering if it got loose after they worked on the thermostat, are you getting no sensors activity at all or a loud beep with red dots?
Old Mar 30, 2025 | 12:06 AM
  #42
W205C43PFL's Avatar
I see, hopefully they make you whole.
Old Mar 30, 2025 | 12:08 AM
  #43
W205C43PFL's Avatar
I know this might sound obvious but is the Parktronic off button turned to on with the led light showing it on by chance?
As in if that light is on, the system is off.
Old Mar 30, 2025 | 12:46 AM
  #44
kcxbaek's Avatar
2019 c63 cabriolet
if you are talking about “P” with 3 lines with “OFF” , its on, and even if i press it or press and hold, tiny red light stays on,
when i put gear in to D, it animates red dots all around beep, parking sensor not functioning but it detached cars coming. so confusing lol
Old Mar 30, 2025 | 10:09 AM
  #45
W205C43PFL's Avatar
Yes, that light shouldn't be on.
Yup, you answered my question, I was asking if there were red dots, that beep is what we were talking about, it indicates sensor fault. The system disables all sensors and the entire system if it detects a sensor fault, you will need a scanner to determine which sensor is the issue and check WIS to see which number sensor indicates which sensor. Just get the dealership to fix it at this point.
Old Mar 30, 2025 | 11:20 AM
  #46
W205C43PFL's Avatar
Reason why I know it is sensor fault is because I literally have that issue before with PARKTRONIC, turns out, in my case at least, moisture corroded the pins of the harness to my front sensors. Hopefully yours is just a loose cable. I had to use XENTRY (I assume a good scanner can tell as well) to know what number sensor is causing the issue, then I need to use WIS to check which number sensor is which and located where. The stored code only mention the sensor number not where it is.
Old Mar 30, 2025 | 11:21 AM
  #47
W205C43PFL's Avatar
Reason why I think in your case is a loose cable is because they just did work on it : ), meaning they might had made something become loose, the likelihood of things corroding is much less.
Old Mar 30, 2025 | 11:26 AM
  #48
kcxbaek's Avatar
2019 c63 cabriolet
i think so too, ill keep posted after visiting!
Old Mar 30, 2025 | 11:29 AM
  #49
kcxbaek's Avatar
2019 c63 cabriolet
[QUOTE=W205C43PFL;9135397]Yes, that light shouldn't be on.
hopefully its just loose cable or something because when i picked up this wasn’t showing any issue theb its just appeared
Old Mar 30, 2025 | 11:32 AM
  #50
W205C43PFL's Avatar
Ya, even more likely a loose cable now, maybe the work they done made something loose or they had to unplug the sensors and didn't fully latch so when you start driving it, the bumps on the road, the stiff suspension or even potholes was the final trigger to make the cable fall off and disconnected the sensor.
