C63/C63S AMG
Obd2 error codes what do the mean
Old Mar 30, 2025 | 07:16 AM
rnbguy's Avatar
e240 w211
Hi does anyone know what these generic error codes mean?
Symptoms are my car won't.start sometimes until.i leave it for a while, changed battery and had starter tested still same.
I wanted to see if it's esl or if these codes can help.. can anyone translate these for the 2016 c63s amg?
Old Mar 30, 2025 | 12:14 PM
W205C43PFL's Avatar
Might be MB specific codes. Use a scanner that can scan MB codes.
Old Mar 30, 2025 | 12:16 PM
W205C43PFL's Avatar
That said, with that many codes happening all at once, it is usually an electrical voltage issue, so I am thinking it might be a bad battery. Depending on the age of the vehicle, the battery might need replacement.
Old Mar 30, 2025 | 12:17 PM
W205C43PFL's Avatar
Check the timestamp on the battery, it is located in the engine bay if I recalled correctly, check the terminals, tell us what date it is produced, if you need help reading it, post the picture here.
