C63s ceramic brake questions
The issue I'm having right now is a squeal on the left-front, and I noticed the 'groove' on the disc. It is very much on the surface and I cannot 'hook' my fingernail on it. Still, it doesn't sit well with me. The wear indicator looks ok-ish, it is still flat. no pits or cavities.
Question(s): any ideas on how? Some debris on the pads? Pads gone bad already? What is the typical choice of this forum for daily brakepads for the ceramic discs?
Any insights are greatly appreciated. I need to find/order an adapter to jack the car up myself.
Related threadL https://mbworld.org/forums/coupe-roa...ake-noise.html
The circled circle appears to be the "wear indicator" circle ... WIS has a procedure to use that to check CCB rotor wear -- but don't believe/use it. I've posted a white paper (search the forum) that indicates it's pretty much useless for that purpose. The only wear indicator that's definitive is the Carboteq tool.
There does appear to be some other pad/material deposits on your rotor, but it's uneven (e.g., the streaks in the lower part of your drawn circle). Getting a uniform pad deposit (bedding in) with these CCB rotors is "challenging."
What pads are you guys you using with CCB? Very curious to hear. I believe i now have the standard AMG ones, but not to impressed.
Pads looked 'okay', are a year old but have seen some heat. There are some chips on it, but nothing that would indicate that line on the rotor as mentioned above.
