C63/C63S AMG
W205 Camber help
Old Jul 22, 2025 | 01:50 AM
Macsgoodlife's Avatar
C63S Coupe
W205 Camber help
I have a C63S Coupe and have been looking for ways to correct my camber front and rear. Im lowered on KW HAS suspension and running Rohana 20" wheels. Front is at -3.5°, I'm looking to be under -
1.5°
Old Jul 22, 2025 | 05:09 AM
ygmn's Avatar
2015 E400 Sedan
google kmac or adjustable camber MErcedes.
Old Jul 22, 2025 | 01:36 PM
C63S Coupe
I've seen the part, but it doesn't have any reviews. I look to see if anyone has any experience with these bushings and there's no information. I've seen modified W205/C205 C63s, but there's no information being spread. Been learning the costly way.
Old Jul 23, 2025 | 04:57 AM
ygmn's Avatar
2015 E400 Sedan
I have them on the rear of my W212 and quite happy as tires now wear much more evenly in lieu of inside edge.
Many threads on this stuff as I research for months before I purchased..
search CAMBER on here and you will see many threads for about every model MB makes.
Old Jul 23, 2025 | 08:46 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W205 AMG forum...
Old Jul 24, 2025 | 12:18 AM
Spicywolff's Avatar
18 c63 s sedan
Kmac is basically our only option. No one that I know makes proper adjustable control arms and top mounts.
Old Jul 25, 2025 | 06:26 AM
K-Mac's Avatar
SPONSOR
Mercedes-Benz CLK 550
BACKGROUND - yes we manufacture front adjustable Top mounts for Macpherson Strut Suspensions. In fact virtually every model upwards from 1968 !
But Mercedes Benz ceased strut (top mount) suspensions after 2018. Now only available on A & B Class models.
These K-MAC adjustable strut mounts are manufactured in 2 versions “Street / Race” and “Full Race”. See K-MAC website re all the unique patented design features.
As above all models after 2018 including W205 C63S Coupe have front upper ‘A’ arms.
Problem installing and accurately adjusting upper arms is time consuming and difficult to access plus also wanting to resolve excess inner edge tire wear reduces all important clearance top of tire to outer fender !
SOLUTION (experience of manufacturing Front and Rear adjuster kits longer than any other brand) IS ADJUSTING LOWER ARMS:
1. REPLACEMENT INNER BUSHINGS - Providing up to “2 extra degrees” Positive or Negative Camber & Caster (more than enough to resolve any excess edge tire wear issues).
2. #1 - Today only alternative is to prematurely fund new tires. (Speed of assembly lines Front Camber and Caster along with rear Camber has been deleted)
3. SECURITY PEACE OF MIND - of not replacing the OEM hi strength forged alloy arms with welded fabricated arms.
4. ADJUSTMENT - K-MAC patented design allows easily accessible precise single wrench adjustment. ULTIMATE - direct on alignment rack UNDER LOAD !
5. FITTING - All K-MAC Front and Rear kits are specially designed - so no special tools required or time consuming need to remove control arms.
6. HANDLING / SAFETY - Forward facing K-MAC Caster bushes are Mono ball / Self aligning. Significantly improving Brake and Steering response.
7. RESEARCH - with K-MAC constantly testing / developing all out 10/10ths - heavy V8 competition racing.
SEE SPOILER RE FRONT & REAR KITS - ALL W205 Models
(Website re kits suit virtually ever Mercedes Benz model 1968 to 2025)
Spoiler
AUDI to VOLVO - K-MAC Experience Of Resolving OEM Suspension Shortcomings (and Costs) Since 1964 !
