C63/C63S AMG
Spark plug indexing?
Old Aug 18, 2025 | 07:41 PM
amg8's Avatar
MY17 C63s Sedan
Does anyone know if we have to index our spark plugs?
Old Aug 18, 2025 | 10:27 PM
W205C43PFL's Avatar
As long as you buy oem ones from the dealership or directly from mbparts.mbusa.com, it is pre-indexed.
Old Aug 18, 2025 | 10:41 PM
W205C43PFL's Avatar
Just make sure to buy from official sources to prevent yourself from having to deal with counterfeits which could potentially destroy your engine. You could also buy from FCPEuro but not all brands sold are pre-indexed, perhaps another forum member can confirm. If in doubt, feel free to ask the FCPEuro staff by calling or using their live chat.
Old Aug 20, 2025 | 04:28 PM
Osgee's Avatar
W211 E55 AMG & W163 ML270
Bought HKS plugs, didn't index them, runs smoother than my friends oem car. Idle is rock solid.
Old Aug 20, 2025 | 05:59 PM
streborx's Avatar
Top Answer: 1
G550
See post #16 at https://mbworld.org/forums/s63-amg-s...-mb-bosch.html
Old Aug 30, 2025 | 12:59 PM
amg8's Avatar
MY17 C63s Sedan
Circling back to this and just wanted to leave some comments in case someone else had the same question. So I am using the OE spark plugs and was told from multiple sources that they come pre-indexed. Meaning you just screw them on and it will align correctly. From what I've researched, the gap part should be pointing towards the fuel injector side with a tolerance of 45 degrees either side. But let me tell you that all the plugs were pointing in all sorts of directions as if they're not indexed. I tighten them down to 22/23Nm. So I am not really sure what to make of that. I just hope this won't cause any major issues.
Old Aug 30, 2025 | 01:36 PM
Sathinas's Avatar
S65
Some will say its the end of the world, because Mercedes says so. And that may be true.
Others, will claim the opposite.
Either way, you might be fine, Jen. Maybe... circle back with us in a few months and tell us how it's doing?
Old Aug 30, 2025 | 01:47 PM
streborx's Avatar
Top Answer: 1
G550
Too bad you didn't inspect the plugs prior to installation and compare the position of the ground electrode with respect to the plug's threading. Maybe we're all being taken for a ride on this indexing thing.
Old Aug 30, 2025 | 02:16 PM
Sathinas's Avatar
S65
Never really bought into the whole indexing thing. We're talking about a combustion chamber that fills with air and atomized fuel on the intake stroke, then gets ignited after the compression stroke. All of that A/F mixture is already... well... mixed before the spark plug(s) fire off. So, pointing the electrode gap right into the injector stream really makes no sense to me. But then again, maybe I'm being over simplistic about the whole thing, since I'm not an ICE ignition engineer.
Old Aug 31, 2025 | 04:09 AM
W140King's Avatar
W140 S320
It is technically in the service info. But I don't think the 177 is included in that indexing requirement but I may be wrong.
Old Aug 31, 2025 | 09:34 AM
streborx's Avatar
Top Answer: 1
G550
Hard to say if it makes a difference with engine performance or longevity, but if it reduces emissions by a gnat's eyelash it's a requirement.
Old Aug 31, 2025 | 10:47 AM
Roysup's Avatar
2018 C63S AMG Coupe, 2019 Jaguar F-Pace SVR
I get it that AMG recommends it... But I would love for someone to explain how not indexing a spark plug can "destroy an engine". There are literally millions upon millions of cars and trucks on the road without indexed spark plugs and they are all doing fine. Perhaps indexing might give you 1 HP more, or .01 MPG more?
Old Aug 31, 2025 | 02:33 PM
user33's Avatar
Try asking Mr. Google:
what is spark plug indexing in amg engines and how is it done
I'm guessing the "danger factor" has to do with flame propagation and component positions. However, regardless of what "people on the internet" say, I'd bet on the wisdom of the engineers at AMG who designed the engine and set the maintenance procedures. While I might push some things, when a very costly engine is involved, I'd take the (seemingly reasonable) extra effort to do it "correctly." It's a simple "cost vs benefit" analysis with (to me) an obvious outcome.
The shop foreman at my (excellent) dealer's service center once shared with me (because he knows I'm a software geek) detailed information on the ECU's adaptive "spark management" that's common to the various V8 engine variants. As I'm sure any of the serious tuners will tell you, it involves a significant number of factors with amazing precision. That's an essential part of how these engines can achieve such a huge dynamic range. My GTR Pro gets about 4.5 MPG (imperial gal) on the track yet gets >23 MPG running briskly on the 400+ km (250 mi) trip from the west coast, over the rocky mountains and on to the track. That's a dynamic range of over 5:1! Amazing.
Old Aug 31, 2025 | 02:44 PM
amg8's Avatar
MY17 C63s Sedan
For what it's worth, even the official WIS/ASRA repair documents don't mention anything about indexing. Not even gapping for that matter.
Old Aug 31, 2025 | 04:26 PM
Roysup's Avatar
@user33 Mr. Google is often full of BS curated by many many "experts" who all are more than happy to declare their knowledge is the only knowledge. I'm not debating that indexing can have negligble performance benefits, but I am doubting that not idexing spark plugs can "destroy an engine". My assessment is supported by the millions and millions of vehicles with non-indexed plugs that are just fine.
Old Aug 31, 2025 | 04:28 PM
Sathinas's Avatar
S65
Bbbb.... Bu.... But Google!
Old Aug 31, 2025 | 10:09 PM
W205C43PFL's Avatar
Is it because of oem plugs being pre-indexed so there is no need to mention it?
Old Aug 31, 2025 | 11:40 PM
amg8's Avatar
MY17 C63s Sedan
My guess is, with the M177, there is no need to index it. Because otherwise when I went to install them, they should all align correctly but they don't.
Old Sep 2, 2025 | 12:53 AM
W140King's Avatar
W140 S320
Good point. But I do recall seeing a document for a few other engines
Old Sep 5, 2025 | 04:18 PM
streborx's Avatar
Top Answer: 1
G550
Mostly out of curiosity, but partly out of eventual need, I ordered a set of MB sparkplugs p/n 0001590500 that fit the M176 engine and several others. Autohausaz's price was $22/ea for the MB branded part, but only $17 for the NGK version and $13.50 for the Bosch version, both which are sold under the MB OE p/n. The MB branded plugs I received have the NGK p/n SILZKFR8E7S stamped on them, so they're probably the same as the $17 NGK plug sold under the MB OE p/n. Autohausaz also sells this SILZKFR8E7S NGK branded sparkplug for $22/ea (go figure).
The curiosity part of my purchase is whether these plugs are manufactured to be identically indexed. Stay tuned -- I'll post a follow-up.
Old Sep 5, 2025 | 09:13 PM
W205C43PFL's Avatar
Hmmm, not sure why some are documented others are not...
Old Sep 6, 2025 | 06:13 PM
Barbalatte's Avatar
C63S
Well my car was misfiring on cylinders 7-8. I replaced all the spark plugs. 7-8 still misfiring . I replaced just that injector and worked for about 2 months. Now cylinder 4 is misfiring. Happens Intermittently. Usually I start the car in the morning and it's fine. When it "warms up" it will start.
im suspecting it could be the indexing of the plugs.
car has now done 51,000km 2019 build year
Old Sep 6, 2025 | 08:19 PM
Roysup's Avatar
Have you had your coils replaced since they have a known defect?
Old Sep 6, 2025 | 09:49 PM
streborx's Avatar
Top Answer: 1
G550
Orientation of a spark plug is unlikely to inhibit ignition. More likely are the coils or injectors (assuming the plugs are OK).
Old Sep 7, 2025 | 01:56 AM
Barbalatte's Avatar
C63S
I haven't changed the coils. I don't think MB Australia recalled the cars for this issue. I think it was only for the US market.
in saying that, the injector was the problem with that 7-8. After we swapped out all the plugs, we did have a defective plug on Cylinder 6. We swapped it out and fixed the problem. I'm thinking it could be the same thing.
