Wheel bearings?
Dealer telling me something about transmission not sure how that could be related
https://files.fm/f/9edq9phuw2
So did we...over and over again. Oddly, it was not leaking any air. Reason is bugs me is that a rim is far lower price than what I paid for two front wheel bearings and a drivers side axle (and the other shaft it needed). There is also a chance it could be a broken belt in a tire. For me, I no longer go right to the bearing.
What also happened in my case is that I had the noise on the right side fist, and then it moved to the left after putting on new tires. I'm guessing the wheels swapped sides and the noise travelled with the wheel that was on the right before. So if you take off the wheels and swap them side to side, and the noise moves, changes or even goes away, then you definitely have the same issue.
Interesting, will try swaping the wheels side to side and see what happens
Yes I have the RXC wheels. In my case, sound is much more pronounced when car is well warm, you can barely hear it when cold….
@superswiss you had the noise in normal driving as well or just when sharp and slow turnings like me?
Did you check the wheel (bearing) for excessive play? ie. rocking the wheel back and fourth (in theY axis) with the wheel bolted up? If so, how did it feel?
Any excessive play here would narrow it down…
Good Luck
Yes, got the bearing replaced yesterday and sound is gone…
So sound was gone after wheel bearing replacement, but a slightly different sound has now came up…🤔
Looks like it is the wheels issue @superswiss mentioned, we have sand just a bit the inner wheel and brake hub (which had lots of rusty) and the noise has almost disappear
So we will do a thorough cleaning and let see
Now I have the same noise in the rear wheels, so will do the same as with the front which solved the issue 100%
@superswiss did this happen to you in the rear wheels as well?
@superswiss How did you get this done? You remember if they sanded the wheels deep or Just superficial?
Sorry I’m coming with this over and over 😬
