C63 S205 intermittent hesitation/dead throttle
I have just purchased a 2016 non S S205 with 54000K on it, the car is really clean and has full Merc history and if anything has been over serviced in it's life. The issue is that it has an intermittent issue with the engine power/throttle pedal just going dead, it seems to happen at low revs i.e. 1000-2000 rpm and can happens when it feels like it . the revs drop off and sink to around 750 rpm an the throttle pedal will become useless for anywhere between 1 second to 5 seconds (It's a joy coming out of junctions ) The ther day i did a 400 mile round trip and it didn't happen once, then i went out the other night 15 mile round trip and it did it twice. It happens in any mode . It has been in to my main dealer and they said it has no fault codes. I am at the point of handing the car back as the dealership i purchased it off are a little slow at reacting. I Have had a few of these and the old S204 and i know they can be quirky at times but i have never had anything like this. It almost feels like fuel or ignition but it had plugs less than 10K ago and i would expect the fault to be present all the time if this was the case . Mercedes said it could be pointing toward the clutch unit in the box but couldn't be sure. Any help would be great .
If revolutions stay on 750/u-min and nothing
happens if you push pedal - i dont think there is a problem with transmission.
If Xentry noting tells - that tells us something.
can you uploade video to YT ?
i dont like to click unknown files !
750 u/min is idle speed.
are you sure it stops there if problem is aktive or comes idle more down ? it looks like near 500 u/min.
Looking at it yes it seems to drop to near 500 , my mistake. It then just picks up and it can be fine again for the rest of the day . I’ve just been out now and it’s done it 4 or 5 times and the gearbox has gone proper clunky like someone’s kicking you in the back every gearbox change
Just as an aside note, either way this car is not a 20k miles/year easy going commuter car even once you get this issue sorted. Especially given that it is now 10 years old. The consumables alone will set you back quite a bit. I get at most about 16k miles out of the brakes, so you are looking at a full brake job once a year, not to mention the tires you gonna go through. This thing loves to eat tires and brakes for breakfast.
However, if you get clunking from the transmission, then I would agree that there might be something going on with the clutch or the rest of the transmission..
i had one situation … combi is blinking - the radar !
i didnt know whats happend - why ?
piep i do not remember anymore.
On the same day i put the front star away ( DIY all black) and i saw a old leaf from a three on the sensor !
( inside)
clunking transission - the question is in situation of this idle fail or not ?
The beeping is the collision detection sensor as a car was slowing in front of me to turn in and that’s when this occurred . From what I can see from the last owners dash cam he left in it’s been driven for the last 4 years like Miss daisy 😂🫣 The dealership have offered to sort it but I fear it could be the case of multiple attempts 🤷♂️
im not worried about the cost to be honest . I’ve run two S204 C63’s back in the day doing 28k one year, and yes not as cheap as a Passat granted 😂😂. If you want to know expensive running try a Ferrari FF for 12 months 😂😂 makes these things look like running a Clio diesel !!
thank you
you need a very good mechanic !
the M177 ls1 is maximum of fuel efficient like a clio diesel - thats true.
Thats what I thought , although since I posted this I managed to speak to the old owner of 4 years and he said it had done since he had it and just thought it was a quirk of them 🤷♂️. He said it did it really bad on Shell V Power , less on Tesco and it was a lot better on BP and Esso which blew my mind 😂. I’ve had the back seat out and checked the Fuel pump control unit and the pump connections and they all looked good , I was about to whip the pump out and in typical UK weather it started raining 😂. It’s going back in to Merc on Wednesday for Belts and more Diagnostics done I’m going to point them toward the fuel pump and coil packs .
