C63/C63S AMG
C63s valves
Old Mar 27, 2026 | 02:48 AM
userr177's Avatar
C63s valves
Hi, on my C63S, I had the performance exhaust, but the previous owner replaced it with a full cat-back exhaust system that uses oem valve motors. Now, when I turn on the car for about 5 seconds I hear a ticking noise coming from the back by the valves. The valve button works until stops after the ticking stops. It doesn’t do anything after that. Why could this be?
I also checked underneath the car everything seems to be plugged in.
Old Mar 27, 2026 | 07:01 AM
C63s_Jack's Avatar
AMG C63s Coupe
Originally Posted by userr177
Hi, on my C63S, I had the performance exhaust, but the previous owner replaced it with a full cat-back exhaust system that includes valves.
Which Brand ?
I only know aftermarket exhausts which they use the oem valve e-motors. it makes sense.
Ask them.
Old Mar 27, 2026 | 11:35 AM
userr177's Avatar
Originally Posted by C63s_Jack
Which Brand ?
Ask them.
Its a redstar exhaust I got in contact with them they said that once the valves are hooked up the inside exhaust button should work
Old Mar 27, 2026 | 01:22 PM
C63s_Jack's Avatar
AMG C63s Coupe
Whats that for a answer ?
the question was :
​​​​​​Now, when I turn on the car for about 5 seconds I hear a ticking noise coming from the back by the valves.
i can see only pipes but not exhaust in the www from them.
can you make a short YT video ?
Old Mar 27, 2026 | 03:00 PM
userr177's Avatar
the question was :
The answer was for when you asked about the brand and I didn't explain quite right about the valves which you were correct they are the oem e motors and upon checking they are connected and as for the website Yes I know Redstar discontinued their exhaust system 3 years ago now they only make downpipes for c63s now thanks for your help
Old Mar 27, 2026 | 03:50 PM
C63s_Jack's Avatar
AMG C63s Coupe
Okay sounds like problem solved.
