CL-Class (W215) 2000-2006: CL 500, CL 600
Looking into aftermarket rims, what offset is correct?
Old Jun 30, 2005 | 12:12 AM
SilverCL02's Avatar
Cool Looking into aftermarket rims, what offset is correct?
Does anyone know the stock offset, and also what offsets clear the calipers? Thanks in advance.
Old Jul 5, 2005 | 02:51 PM
AMG2GO's Avatar
NSX
Stock offset is +44 on 18" 2003+ models. But they all vary +44 to +46. clearing the calipers is a function of diameter not offset. If you are not going with smaller diameter wheels you will be fine. if you increase wheel width you will need to adjust offset accordingly.
Old Jul 5, 2005 | 08:49 PM
grussell's Avatar
2024 GLE53
I went with 19" x 8.5" front and 19" x 9.5" rear, both at +38 offset. I am happy with the fitment.
Old Jul 6, 2005 | 05:34 PM
SilverCL02's Avatar
Thanks for the replies.
The reason I ask is that a friend of mine had his rims scrape off a mm or so from his rear calipers, with 18's. I am thinking they were 35 mm offset then.
