CL-Class (W215) 2000-2006: CL 500, CL 600
Brake Assist BAS & Elec. Stabil. Prog. ESP
Old Mar 14, 2006 | 08:08 PM
franck's Avatar
My wife's CL500 has 2 warnings popping up from time to time:
1/ Brake Assist BAS Visit Workshop !
2/ Elec. Stabil. Prog. ESP Visit Workshop!
The problem is that if we stop the engine & starts it again,these will not appear anymre for days & then 1 morning they will be back, etc.....
On top of that, any little bump on the road gets the car's OBC makes a little "dong!", but no malfunction is actually popping up in the OBC screen.
We sent the car to 2 workshops, both they could not find the actual problem.
Has any of you guys had a similar experience ?
What should we do ?
Thanks a lot!
Franck
Attached Thumbnails Brake Assist BAS & Elec. Stabil. Prog.  ESP-image_00001.jpg   Brake Assist BAS & Elec. Stabil. Prog.  ESP-image_00002.jpg
Old Mar 14, 2006 | 08:16 PM
BeNzTeK's Avatar
Could be what happened to me sometimes ,with the tip start it doesnt always engage and doesnt start causeing these warning lights to come on I would then turn the car off and restart it problem went away.
-Also could be what we call GHOST CODES?
-Try taking it to MB and have them grease up the flywheel There is a certain grease for this it is for the tip start?
-Have it do it so the light stays on DONT SHUT THE CAR OFFF and take it to mb see what it codes up for.
-Could be a simple stop lamp switch
Old Mar 15, 2006 | 12:21 AM
franck's Avatar
Thanks for your help.
I actually pops up a few minutes after driving. I then stop the car, turn OFF the engine & then ON & no more malfunction.
Quite weird as the 2 workshops I took it to could not find anything wrong.....
Old Mar 20, 2006 | 03:58 PM
consultazione's Avatar
I have the same problem on my s class.
have you found the solution?
Old Mar 20, 2006 | 07:48 PM
Kar don's Avatar
Mercedes-Benz
where are you located, and i think the other poster was suggesting to take it directly to the dealer when the warning comes up and do not shut the car off.
