CL-Class (W215) 2000-2006: CL 500, CL 600
02 CL500 Lowering
Old Jul 4, 2006 | 09:56 PM
neonflx's Avatar
02 CL500 Lowering
is there a safe method to lower a 02 CL500, thanks
Can I use the Star Diagnostic?
Module or Washer method?
Old Jul 5, 2006 | 01:47 AM
David M///'s Avatar
CL600 Sport
You'll find many posts on this subject if you use the search function, but here's a link to the one I posted:
https://mbworld.org/forums/cl-class-w215/135347-cl-loweringo-revisited.html
Old Jul 5, 2006 | 03:31 PM
neonflx's Avatar
David M
thanks for the info i ordered the linkage from tws, i live in seattle so i will have to do the install myself, he recommended to use the manual to locate the places where to install, i am mechanicaly inclined and have access to any tool and also a lift is there a place where i can purchase the service manual prefebly in pdf or cd/dvd format thanks again
Old Jul 5, 2006 | 11:43 PM
David M///'s Avatar
CL600 Sport
No problem. Good luck with the install. Don't forget to use locktight on the front upper bolts, and use the factory captive nuts where you can.
David
Old Jul 6, 2006 | 12:15 PM
OC kid's Avatar
ex 03 W215 now 08 e92 M3
Thanks David M///
Just wanted to say thanks for all the research and info.
I have to say I agree with your decision as this seems to be the easiest, most flexible, cost effective, and not to mention; reversable solution.
After this Brea job today I'm gonna stop by over to see the boys up in Walnut.
This is why MB world is good stuff...now if only if they would get the W216 forum up and running!!!
Mr. Vanos- "You here me in the back?!!"
Old Jul 7, 2006 | 01:10 AM
David M///'s Avatar
CL600 Sport
You're very welcome. How convenient for you to be in OC too. Tell Sander I said hello. Good luck!
David
