what's the easiest way to change the fog bulbs with the amg package
03 cl500,04 range rover, 04 cayenne turbo, 08 yukon denali
Is there an easier way than going in thought the mesh? I felt under the front valence but i can't seem to locate any access panel? I'm trying to change the bulbs to match the HID's
Received 1,097 Likes
E55, GLS450, GL63, GLE350
There are two panels with multiple bolts holding them on. It's kind of a pain to remove them all and be prepared to get dirty. The best way is to drive your car up on ramps so you will be able to crawl under there to access the bolts.
How about the standing lamps? I cant seem get them out without removing the ballast..Is there anyway to remove them without removing the whole light assembly..
Darn,,,
You must have really small fingers
Are you supposed to twist it or do you just pull it out?? I can't seem to get in there at all..
Where is everyone on this board..It's starting to suck here...Maybe I need a new car
