Cl600 Accelerator Delay And Check Engine Light On.
https://mbworld.org/forums/s-class-w220/217436-acceleration-problem.html
Before you do anything, find out why the check engine light is on. I would either invest on an OBD tool, or have the code looked up by someone.
Good luck!
if this doesnt work then i will run the codes. but what was explained in the link you posted is exactly what i am experiencing. thank you thank you thank you
http://www.autohausaz.com
http://www.autopartswarehouse.com
http://www.buymbparts.com
http://www.performanceproducts4benz.com
http://www.mercedesshop.com
Good luck and let us know how it goes.
