CL-Class (W215) 2000-2006: CL 500, CL 600
ABC issue????
Old Apr 29, 2008 | 11:49 AM
kineticBENZ's Avatar
03 CL 500 sport, 97 Widebody NSX-T, 04 996 C4S, 02 528i sport, 06 GSX-R 600
ABC issue????
Hey guys...
My ABC sign turned on the other day and today under the CL, I found a pretty large puddle of what seems to be hydrolic fluid. Not sure, but I think it is...
Whats going on with this damn car????
Any help or thoughts are greatly appreciated!
Thanks!
-Patrick
Old Apr 29, 2008 | 10:13 PM
calgary's Avatar
2001 Mercedes CL500 2006 E350 4-matic
Originally Posted by kineticBENZ
Hey guys...
Thanks!
-Patrick
Did you check the reservoir of the power steering/ABC pump?? If it shows no fluid you look at an expensive pump replacement. Unfortunately that happens to the CL quite often - according to this forum - It cost me over can$2,000.
Old Apr 30, 2008 | 12:27 PM
wease206's Avatar
W215/X164/C124
how do you know you abc is in a great shape
Old Apr 30, 2008 | 12:55 PM
You dont ill it ****s on you... But how does this help with my issue???
Old Apr 30, 2008 | 04:36 PM
~CL500~'s Avatar
E90 N54 & W251
Hey guys...
Thanks!
-Patrick
Patrick,
Prior to finding the puddle of ABC fluid, did the car make any "whining" noises when turing the sterring wheel at low speeds? Kinda lika a bad power steering pump would make. That is usually the sign of the ABC pump going bad.
If that is not the case, then hopefully it's just an ABC hose that's leaking. You then need to fix the hose and flush the system wth new fluid. Avoid running the engine as there is no fluid in the system. That will damage the ABC pump if it's not already damaged. Regardless, this sounds like a mandatory dealer visit.
Good luck.
Old May 1, 2008 | 10:50 AM
Originally Posted by ~CL500~
Patrick,
Good luck.
No... No whining noise at all. Thinking back I did hear kind of a POP noise from under the car a few days ago. Anyway... I too the car to a local machanic friend of mine and he said that I blew a strut on the front drivers side. He has worked on all of my cars and with much better results than I have ever had from a dealership!!!! However he is not familiar with our ABC systems so he is sending me to the dealership on this one... "damn"
But does his diognosis sound correct? would a ruptured strut throw up a ABC sign on the cluster?
Thanks for your reply... I found it very helpful and printed it out to take to the dealer with me.
-Patrick
Old May 1, 2008 | 11:06 AM
reddog's Avatar
'03 CL500,& '18 GLS63. Gone: '83 500SEC,'99 500SL,'07GL450
On my 2003 CL500 "new,corrision resistant ABC high-pressure distribution hoses" were replaced under:
"Recall: 04V228000: ABC Pressure Hose Corrision".
Old May 1, 2008 | 07:17 PM
Jud Chapin's Avatar
'16 S550 Coupe, '11 Lexus LS460, '02 CL500 (SOLD)
Ditto on my '02.
Old May 1, 2008 | 07:43 PM
Could that be the problem? How long ago was your lines replaced by MB?
Thanks!!
Old May 1, 2008 | 08:32 PM
bltserv's Avatar
2005 SL55, 2000 CL500
Ditto on my MY 00
Corrision resistant ABC high-pressure distribution hoses installed under recall.
Like 3 years ago. Thats an old recall I think.
It could be a strut seal or a hose.
Thats good news at least vs. a Pump Replacement.
As others have said. Thats a Dealer Only type repair.
Keep us informed what it was and how much they soak you for.
Old May 2, 2008 | 05:18 AM
tusabes's Avatar
Mercedes
Take it into the dealer for the free ABC hose replacement recall...that will be free.
if your strut is blown it will leak again when they redo the hose and theyll tell you.
Better than telling them to check the strut, incurring diagnostic charges if just the hose blew.
