CL-Class (W215) 2000-2006: CL 500, CL 600
Wheel Balancing
Old Jan 13, 2009 | 07:55 PM
Jud Chapin's Avatar
'16 S550 Coupe, '11 Lexus LS460, '02 CL500 (SOLD)
Wheel Balancing
Does anyone have trouble keeping their wheels balanced? Mine seem to last just a few thousand miles. I don't know whether I'm throwing weights or what. I always have them put the weights on the inside as I don't like the looks of them on the outer rim.
Old Jan 14, 2009 | 02:49 PM
~CL500~'s Avatar
E90 N54 & W251
It's either you're loosing the weights or pot holes, which I doubt is an issue in your area. How are your tires and wheel alignment? I'm guessing you have some thumping symptoms while you drive which are usually attributed to balancing, but have you checked the alignment?
Old Jan 14, 2009 | 03:33 PM
Jud Chapin's Avatar
Yes, the car has been aligned. When they balance these tires using weights only on the inside rim, they have to be glued on if they're like my Vette. I think they just do a crappy job and the weights come off, but I'll find out when I get my rear tires replaced. Thanx.
